Ga door naar hoofdinhoud
Fahrenheit FHT 125PRMR Motherboard Replacement
Wat je nodig hebt
  1. Fahrenheit FHT 125PRMR Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Remove both hinge covers on each side of the flat iron.
  2. Fahrenheit FHT 125PRMR Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Using Philips head #2 remove the 7 mm black screw that was underneath one of the hinge covers.
  3. Fahrenheit FHT 125PRMR Motherboard Replacement: stap 3, afbeelding 1 van 2 Fahrenheit FHT 125PRMR Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Using the metal spudger, push through the hole the screw was removed from. Doing this will push the copper pin out of the other side.
    • When the pin is removed the two sides of the device can now separate.
    • Be sure to collect the spring that is next to the hinge when they are separated.
  4. Fahrenheit FHT 125PRMR Motherboard Replacement: stap 4, afbeelding 1 van 2 Fahrenheit FHT 125PRMR Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Using Philips head #1 remove the 6 mm black screw that was underneath the spring as well as the 6 mm black screw next to the heating plate. Remove the panel the screws were holding down.
  5. Fahrenheit FHT 125PRMR Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Using Philips head #1 remove the two 4 mm silver screws on the sides of dial panel cover.
  6. Fahrenheit FHT 125PRMR Motherboard Replacement: stap 6, afbeelding 1 van 2 Fahrenheit FHT 125PRMR Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Using Philips head #00 to remove the 4 mm silver screw on the dial. Remove the dial with your hand.
  7. Fahrenheit FHT 125PRMR Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Remove the covering panel by pulling up with your hand.
  8. Fahrenheit FHT 125PRMR Motherboard Replacement: stap 8, afbeelding 1 van 2 Fahrenheit FHT 125PRMR Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Remove three 3 mm sliver screws #1 from the motherboard.
    • Use your hand to life the motherboard out of the flat iron.
  9. Fahrenheit FHT 125PRMR Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Desolder the two white, one red, and one black cables from the mother board to remove all connection to the flat iron.
    • Hoe moet je (de-)solderen?
Conclusie
MeKenzie Hilsmeyer
23 Reputatie
1 Handleiding geschreven
IUPUI, Team 2-2, Harley Fall 2016 Lid van IUPUI, Team 2-2, Harley Fall 2016
IUPUI-HARLEY-F16S2G2
4 Leden
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 1,630
