Ga door naar hoofdinhoud
ExoPC Slate Camera Replacement
Wat je nodig hebt
    1. ExoPC Slate Camera Replacement, Camera: stap 1, afbeelding 1 van 1
      • Turn the PC on its back with the screen facing down and pull on the piece of plastic shown in the image. Use your fingernails to prod into the depression where the two plastic covers meet.
      Vraag FixBot
      Voeg opmerking toe
    2. ExoPC Slate Camera Replacement: stap 2, afbeelding 1 van 1
      • Using the 00 Phillips screwdriver remove the two screws in the corners.
      • Using your left hand pull at the exposed section of the PC while simultaneously pushing the right with the thumb of your other hand. This will release the plastic clips allowing back cover to slide off, as shown from the picture
      • When removing the back cover make sure that the ribbon connectors going to the screen are not damaged. Carefully fold over the cover like a book.
      Vraag FixBot
      Voeg opmerking toe
    3. ExoPC Slate Camera Replacement: stap 3, afbeelding 1 van 1
      • Remove the tape covering the metal shield.
      • Remove the 12 screws using the Phillips #00 screwdriver.
      • Dislodge the shield by pulling the prongs away from underneath the battery. The shield should come completely off.
      Vraag FixBot
      Voeg opmerking toe
    4. ExoPC Slate Camera Replacement: stap 4, afbeelding 1 van 2 ExoPC Slate Camera Replacement: stap 4, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Use tweezers to disconnect camera cable from motherboard.
      • Remove the Phillips #000 screw that holds the camera in place.
      • Gently remove the camera.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Aaron Moore
217 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S2-G1, Peak Fall 2018 Lid van UMass Dartmouth, Team S2-G1, Peak Fall 2018
UMASSD-PEAK-F18S2G1
3 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 44
Altijd: 544
