Ga door naar hoofdinhoud
ExoPC Slate CPU Fan Replacement
Wat je nodig hebt
  1. ExoPC Slate CPU Fan Replacement, Back Cover and Shield: stap 1, afbeelding 1 van 2 ExoPC Slate CPU Fan Replacement, Back Cover and Shield: stap 1, afbeelding 2 van 2
    • Turn the PC on its back with the screen facing down and pull on the piece of plastic shown in the image. Use your fingernails to prod into the depression where the two plastic covers meet.
    Vraag FixBot
    Voeg opmerking toe
  2. ExoPC Slate CPU Fan Replacement: stap 2, afbeelding 1 van 2 ExoPC Slate CPU Fan Replacement: stap 2, afbeelding 2 van 2
    • Using the 00 Phillips screwdriver remove the two screws in the corners.
    • Using your left hand pull at the exposed section of the PC while simultaneously pushing the right with the thumb of your other hand. This will release the plastic clips allowing back cover to slide off, as shown from the picture
    • When removing the back cover make sure that the ribbon connectors going to the screen are not damaged. Carefully fold over the cover like a book.
    Vraag FixBot
    Voeg opmerking toe
  3. ExoPC Slate CPU Fan Replacement: stap 3, afbeelding 1 van 3 ExoPC Slate CPU Fan Replacement: stap 3, afbeelding 2 van 3 ExoPC Slate CPU Fan Replacement: stap 3, afbeelding 3 van 3
    • Remove the tape covering the metal shield.
    • Remove the 12 screws using the Phillips #00 screwdriver.
    • Dislodge the shield by pulling the prongs away from underneath the battery. The shield should come completely off.
    Vraag FixBot
    Voeg opmerking toe
  4. ExoPC Slate CPU Fan Replacement, CPU Fan: stap 4, afbeelding 1 van 2 ExoPC Slate CPU Fan Replacement, CPU Fan: stap 4, afbeelding 2 van 2
    • Remove the yellow tape securing the wires to the PCB board as well as the silver/grey tape.
    • Unscrew the six Phillips #00 screws.
    Vraag FixBot
    Voeg opmerking toe
  5. ExoPC Slate CPU Fan Replacement: stap 5, afbeelding 1 van 2 ExoPC Slate CPU Fan Replacement: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Using tweezers, disconnect the connector in the top left.
    • Pull the fan heat sink away from the PC.
    • Remove the fan from the copper heat sink with the tweezers by releasing the metal clips.
    • Apply a sparing amount of thermal paste to each chip.
    • Attach the new or cleaned fan to the heat sink using the metal clips. Line up the heat sink with the screw holes and press down firmly to spread out the thermal paste.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Jonathon Cronin
337 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team S2-G1, Peak Fall 2018 Lid van UMass Dartmouth, Team S2-G1, Peak Fall 2018
UMASSD-PEAK-F18S2G1
3 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 24
Altijd: 605
