Ga door naar hoofdinhoud
Eureka 1660SP Extendable Pole Realignment
Wat je nodig hebt
    1. Eureka 1660SP Extendable Pole Realignment, Motor Housing: stap 1, afbeelding 1 van 2 Eureka 1660SP Extendable Pole Realignment, Motor Housing: stap 1, afbeelding 2 van 2
      • Before you start, make sure your vacuum is unplugged the power outlet.
      • Press and hold down the black button below the handle while pulling the pole out.
      Vraag FixBot
      Voeg opmerking toe
    2. Eureka 1660SP Extendable Pole Realignment: stap 2, afbeelding 1 van 2 Eureka 1660SP Extendable Pole Realignment: stap 2, afbeelding 2 van 2
      • Press the black separator switch to separate the top and bottom halves of the vacuum.
      Vraag FixBot
      Voeg opmerking toe
    3. Eureka 1660SP Extendable Pole Realignment: stap 3, afbeelding 1 van 3 Eureka 1660SP Extendable Pole Realignment: stap 3, afbeelding 2 van 3 Eureka 1660SP Extendable Pole Realignment: stap 3, afbeelding 3 van 3
      • Use a #2 Phillips head screwdriver to remove six 13.9mm screws from the side of the motor housing (top half) as shown.
      • Remove two 14.1mm screws from the front face of the housing. You are now all set to open the housing.
      • Keep a watchful eye on the two screws from the front face. These two have additional collars to their necks and will not fit in any of the other holes, yet no other screw will fit in their spots without the collar.
      Vraag FixBot
      Voeg opmerking toe
    1. Eureka 1660SP Extendable Pole Realignment, Realignment of the extendable pole: stap 4, afbeelding 1 van 1
      • Once the housing is open, locate the solid chrome plated piece at the front end of the extendable pole.
      Vraag FixBot
      Voeg opmerking toe
    2. Eureka 1660SP Extendable Pole Realignment: stap 5, afbeelding 1 van 2 Eureka 1660SP Extendable Pole Realignment: stap 5, afbeelding 2 van 2
      • On the side of the motor housing which does not hold the engine, find the center track which runs along the inside of the housing.
      • Re-insert the chrome plated piece into the center track.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Evan Fodi
122 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013 Lid van UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G1
3 Leden
18 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 30
Altijd: 827
