Ga door naar hoofdinhoud
Eton FRX3 Tuning Dial Replacement
Wat je nodig hebt
    1. Eton FRX3 Tuning Dial Replacement, Rechargeable Battery Pack: stap 1, afbeelding 1 van 1
      • Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
      Vraag FixBot
      Voeg opmerking toe
    2. Eton FRX3 Tuning Dial Replacement: stap 2, afbeelding 1 van 1
      • Disconnect the battery pack wires from the device and remove the battery pack.
      Vraag FixBot
      Voeg opmerking toe
    1. Eton FRX3 Tuning Dial Replacement, Case Assembly: stap 3, afbeelding 1 van 1
      • On the bottom of the device case's face are two T10 screws. Use a T10 Torx screwdriver to remove the two screws.
      Vraag FixBot
      Voeg opmerking toe
    2. Eton FRX3 Tuning Dial Replacement: stap 4, afbeelding 1 van 1
      • While using the T10 screwdriver, remove the two T10 screws on the back of the device's case.
      Vraag FixBot
      Voeg opmerking toe
    3. Eton FRX3 Tuning Dial Replacement: stap 5, afbeelding 1 van 1
      • Remove the two Phillips #00 screws located in the center of the back of the device.
      • You will need to use a thin shafted screwdriver or a female hexagonal bit that is found in the iFixit 54 bit toolkit to extend the reach of the Phillips #00 bit.
      Vraag FixBot
      Voeg opmerking toe
    4. Eton FRX3 Tuning Dial Replacement: stap 6, afbeelding 1 van 1
      • On the bottom of the device's case there are two rubber feet. Pry the rubber feet off of the case.
      • Try to keep the adhesive on the rubber feet as clean as possible to insure that they can be reattached during reassembly.
      Vraag FixBot
      Voeg opmerking toe
    5. Eton FRX3 Tuning Dial Replacement: stap 7, afbeelding 1 van 1
      • Pull the two halves of the device's case apart.
      • Take care when pulling the two halves apart. There are three cables that connect components of the device to the motherboard. Disconnect these cables in order to separate the two halves of the device's case.
      Vraag FixBot
      Voeg opmerking toe
    1. Eton FRX3 Tuning Dial Replacement, Tuning Dial: stap 8, afbeelding 1 van 1
      • Unplug the socket connection from the motherboard as shown in the image.
      Vraag FixBot
      Voeg opmerking toe
    2. Eton FRX3 Tuning Dial Replacement: stap 9, afbeelding 1 van 1
      • Remove the two 1 cm Phillips #0 screws that secure the tuning dial panel to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    3. Eton FRX3 Tuning Dial Replacement: stap 10, afbeelding 1 van 1
      • Gently lift the dial upwards to remove it.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Md Siamul Islam
423 Reputatie
4 handleidingen geschreven
USF Tampa, Team 1-6, Nance Spring 2016 Lid van USF Tampa, Team 1-6, Nance Spring 2016
USFT-NANCE-S16S1G6
4 Leden
26 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 33
Altijd: 1,414
