Ga door naar hoofdinhoud
Epson EX90 Cooling Fan Replacement
Wat je nodig hebt
  1. Epson EX90 Cooling Fan Replacement, Cooling Fan: stap 1, afbeelding 1 van 2 Epson EX90 Cooling Fan Replacement, Cooling Fan: stap 1, afbeelding 2 van 2
    • Place the projector so that the bottom side is facing upwards
    • Remove the eight screws pictured from the bottom of the device.
    • Open the cover.
    • Be careful when opening the cover; a ribbon cable is still connecting the cover to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  2. Epson EX90 Cooling Fan Replacement: stap 2, afbeelding 1 van 1
    • Carefully remove the two parallel wire connectors which connect the fan to the corner of the motherboard.
    • Take care to record the port which each wire comes from, so as not to get your wires crossed.
    Vraag FixBot
    Voeg opmerking toe
  3. Epson EX90 Cooling Fan Replacement: stap 3, afbeelding 1 van 1
    • Remove the three screws pictured, which hold the fan's frame in place.
    Vraag FixBot
    Voeg opmerking toe
  4. Epson EX90 Cooling Fan Replacement: stap 4, afbeelding 1 van 2 Epson EX90 Cooling Fan Replacement: stap 4, afbeelding 2 van 2
    • Remove fan and related assembly from projector.
    • Detach fan from housing.
    • If the fan is still in good condition, use a paper towel or cloth and clean out all the dust on your fan before reassembling.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Lucas Ketchie
160 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 2-3, Mellen Spring 2022 Lid van UMass Dartmouth, Team 2-3, Mellen Spring 2022
UMASSD-MELLEN-S22S2G3
4 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 27
Altijd: 456
