Ga door naar hoofdinhoud
Envizen V100M Speakers Replacement
Wat je nodig hebt
  1. Envizen V100M Speakers Replacement, Back Cover: stap 1, afbeelding 1 van 2 Envizen V100M Speakers Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Remove the two screws on the side of the tablet that hold the back cover in place using the ifixit PH00 screwdriver.
    • The two screws for the back cover are: 1.5mm diameter x 3.5mm long
  2. Envizen V100M Speakers Replacement: stap 2, afbeelding 1 van 3 Envizen V100M Speakers Replacement: stap 2, afbeelding 2 van 3 Envizen V100M Speakers Replacement: stap 2, afbeelding 3 van 3
    • Pry along the edge of the device to separate the back cover from the device.
    • The speakers are attached to the back cover and motherboard assembly so remove carefully.
  3. Envizen V100M Speakers Replacement, Speakers: stap 3, afbeelding 1 van 1
    • Check to see if the wires of the speakers are connected to the motherboard assembly here.
  4. Envizen V100M Speakers Replacement: stap 4, afbeelding 1 van 1
    • take the wires of one of the speakers and solder them back on the mother board, as shown. Remember, Red is always positive (+) and Black is always negative (-). here is a guide on how to solder.
  5. Envizen V100M Speakers Replacement: stap 5, afbeelding 1 van 1
    • Repeat the same process for the second speaker. The other set of terminals for the second speaker is directly next to the first set.
Conclusie
nbach
663 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 3-2, Duarte Spring 2015 Lid van UMass Dartmouth, Team 3-2, Duarte Spring 2015
UMASSD-DUARTE-S15S3G2
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 119
