Inleiding
This guide will help you through taking out and replacing the motherboard, to do so you must complete some prerequisite guides to complete this guide.
Wat je nodig hebt
Remove the two screws on the side of the tablet that hold the back cover in place using the ifixit PH00 screwdriver.
The two screws for the back cover are: 1.5mm diameter x 3.5mm long
Remove the non-conductive tape located on the battery and motherboard assembly.
Remove the solder from the red and black wires from the battery attached to the motherboard. Here is a guide on how to solder.
Remove the red and black wire from the motherboard using tweezers. If tweezers are unable to remove the wires, heat can be used to loosen the solder allowing for the wires to be removed.
Remove the five screws holding the motherboard assembly down using the ifixit PH00 screwdriver
These screws are also 1.5mm in diameter and 3.5mm long
Remove the solder holding the white ribbon cable in place, here is a guide on how to solder.
Then flip the motherboard over to access the screws for the rear facing camera.
