Ga door naar hoofdinhoud
Emson Star Wars R2-D2 Humidifier Fan Replacement
Wat je nodig hebt
  1. Emson Star Wars R2-D2 Humidifier Fan Replacement, Fan: stap 1, afbeelding 1 van 1
    • Remove the top cover of the humidifier by pulling upwards.
    Vraag FixBot
    Voeg opmerking toe
  2. Emson Star Wars R2-D2 Humidifier Fan Replacement: stap 2, afbeelding 1 van 1
    • Grip the dial from the front of the device and gently pull it away to remove it.
    Vraag FixBot
    Voeg opmerking toe
  3. Emson Star Wars R2-D2 Humidifier Fan Replacement: stap 3, afbeelding 1 van 1
    • Remove the blue water tank of the humidifier by pulling upwards.
    Vraag FixBot
    Voeg opmerking toe
  4. Emson Star Wars R2-D2 Humidifier Fan Replacement: stap 4, afbeelding 1 van 2 Emson Star Wars R2-D2 Humidifier Fan Replacement: stap 4, afbeelding 2 van 2
    • Use a PH1 screwdriver bit and 150mm extension to unscrew the four screws from the bottom cover.
    Vraag FixBot
    Voeg opmerking toe
  5. Emson Star Wars R2-D2 Humidifier Fan Replacement: stap 5, afbeelding 1 van 1
    • Remove the blue plastic top by pulling upwards on the middle notch.
    Vraag FixBot
    Voeg opmerking toe
  6. Emson Star Wars R2-D2 Humidifier Fan Replacement: stap 6, afbeelding 1 van 1
    • This is where the fan is located. Carefully remove the fan from its compartment.
    • At this stage, you may remove the pin connector of the fan from the printed circuit board. However, it may be difficult to pull the pin. We recommend removing the printed circuit board for more clearance during removal.
    • Remove the screws on the printed circuit board using the same PH1 driver.
    Vraag FixBot
    Voeg opmerking toe
  7. Emson Star Wars R2-D2 Humidifier Fan Replacement: stap 7, afbeelding 1 van 2 Emson Star Wars R2-D2 Humidifier Fan Replacement: stap 7, afbeelding 2 van 2
    • Grip the fan's connector located on the printed circuit board and pull it away from the connector (see second picture).
    Vraag FixBot
    Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Yash Chari
240 Reputatie
2 handleidingen geschreven
USF Tampa, Team 8-5, Eyestone Spring 2017 Lid van USF Tampa, Team 8-5, Eyestone Spring 2017
USFT-EYESTONE-S17S8G5
4 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 33
Altijd: 1,068
