Ga door naar hoofdinhoud
Ematic eGlide 4 Screen Replacement
Wat je nodig hebt
  1. Ematic eGlide 4 Screen Replacement, Rear Panel: stap 1, afbeelding 1 van 1
    • Remove the 4.6mm Phillips #00 screw at the base of the device.
  2. Ematic eGlide 4 Screen Replacement: stap 2, afbeelding 1 van 1
    • Slide the rear panel away from the base parallel to the screen.
  3. Ematic eGlide 4 Screen Replacement: stap 3, afbeelding 1 van 2 Ematic eGlide 4 Screen Replacement: stap 3, afbeelding 2 van 2
    • Carefully remove the speakers from the rear panel.
    • Pull the speakers off of the rear panel.
  4. Ematic eGlide 4 Screen Replacement, Side Button Array: stap 4, afbeelding 1 van 1
    • Remove the 3 Phillips #00 4.5 mm screws from the side button array.
  5. Ematic eGlide 4 Screen Replacement: stap 5, afbeelding 1 van 2 Ematic eGlide 4 Screen Replacement: stap 5, afbeelding 2 van 2
    • Slide the grey ribbon wire connector clip away from the ribbon wire port on the motherboard using the pointed tip of a spudger. This process will unclip the wire from the motherboard to release connection.
    • You do not need to fully disconnect the ribbon wire clip from the ribbon wire port: the clip will stay attached in a loose fit.
    • Remove the ribbon wire from the ribbon wire port on the motherboard.
  6. Ematic eGlide 4 Screen Replacement: stap 6, afbeelding 1 van 1
    • Remove the side button array from the device.
  7. Ematic eGlide 4 Screen Replacement, Motherboard: stap 7, afbeelding 1 van 1
    • Remove the gold ribbon wire from the ribbon wire port on the motherboard.
  8. Ematic eGlide 4 Screen Replacement: stap 8, afbeelding 1 van 1
    • Slide the grey ribbon wire connector clip away from the white ribbon wire port on the screen board using the pointed tip of a spudger.
    • Remove the ribbon wire from the ribbon wire port on the screen board.
  9. Ematic eGlide 4 Screen Replacement: stap 9, afbeelding 1 van 1
    • Slide the grey ribbon wire connector clip away from the ribbon wire port using the pointed tip of a spudger.
    • Remove the ribbon wire from the ribbon wire port.
    • If you have already removed the side button array you do not need to do this step.
  10. Ematic eGlide 4 Screen Replacement: stap 10, afbeelding 1 van 1
    • Remove the 2 Phillips #00 4.5 mm screws from the motherboard.
  11. Ematic eGlide 4 Screen Replacement: stap 11, afbeelding 1 van 1
    • Desolder the Wi-Fi Adaptor
    • If not replacing the motherboard or Wi-Fi Adaptor, omit this step
    • See ifixit's guide to soldering and desoldering for help: How to Solder and Desolder Connections
  12. Ematic eGlide 4 Screen Replacement: stap 12, afbeelding 1 van 1
    • Desolder the battery connections
    • If not replacing the motherboard or battery, omit this step
  13. Ematic eGlide 4 Screen Replacement: stap 13, afbeelding 1 van 2 Ematic eGlide 4 Screen Replacement: stap 13, afbeelding 2 van 2
    • Slide and pull the motherboard out of its current position, so that the ports disconnect from the device.
    • Lift the motherboard out of the device.
  14. Ematic eGlide 4 Screen Replacement, Screen: stap 14, afbeelding 1 van 1
    • Gently pull the front case clips down and off of the back of the screen
  15. Ematic eGlide 4 Screen Replacement: stap 15, afbeelding 1 van 1
    • Gently pull the front case clips down and off of the back of the screen for all of the remaining clips
  16. Ematic eGlide 4 Screen Replacement: stap 16, afbeelding 1 van 2 Ematic eGlide 4 Screen Replacement: stap 16, afbeelding 2 van 2
    • Gently pull the screen away from the front case
Conclusie
Bailey Hughes
617 Reputatie
6 handleidingen geschreven
Baylor, Team 5-8, Williams Spring 2015 Lid van Baylor, Team 5-8, Williams Spring 2015
BU-WILLIAMS-S15S5G8
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 296
