Inleiding
If you need to open your device or replace the back panel, this guide will show you how.
Wat je nodig hebt
Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
Slide the plastic opening tool down the long side of the device.
Insert tool again and slide it down the long slide of the case a second time.
1Gids Commentaar
Our funtab3 is not work because we want to work but Anything is not work. We see a tiny crack
