Ga door naar hoofdinhoud
Element GC-1020 Display Replacement
Wat je nodig hebt
    1. Element GC-1020 Display Replacement, Back Cover Replacement Guide: stap 1, afbeelding 1 van 1
      • Unscrew the four screws (size: 3.175mm) on the left and right side of the Element Electronics GC-1020 device using the PH#0 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Element GC-1020 Display Replacement: stap 2, afbeelding 1 van 1
      • Carefully pull the back of the device (the silver portion) apart from the rest of the device.
      • If you pull back too forcefully the power button would move out of place.
      Vraag FixBot
      Voeg opmerking toe
    1. Element GC-1020 Display Replacement, Display: stap 3, afbeelding 1 van 1
      • Unscrew the visible Philips head screws (size: 3.968 mm) on the motherboard located on the top of left and right sides. Use a PH #0 sized screw driver head for removal.
      Vraag FixBot
      Voeg opmerking toe
    2. Element GC-1020 Display Replacement: stap 4, afbeelding 1 van 2 Element GC-1020 Display Replacement: stap 4, afbeelding 2 van 2
      • Carefully bend the plastic frame to remove the motherboard.
      • Upon doing this make sure your power button on the bottom left side stays attached to the outer frame because it will loosen as the motherboard is moved upwards.
      Vraag FixBot
      Voeg opmerking toe
    3. Element GC-1020 Display Replacement: stap 5, afbeelding 1 van 1
      • The display is attached to a dark yellow, flimsy, plastic material. This material is then attached to the motherboard. Tear off the plastic, successfully detaching the motherboard and display from each other.
      Vraag FixBot
      Voeg opmerking toe
    4. Element GC-1020 Display Replacement: stap 6, afbeelding 1 van 3 Element GC-1020 Display Replacement: stap 6, afbeelding 2 van 3 Element GC-1020 Display Replacement: stap 6, afbeelding 3 van 3
      • Once the display is by itself, separate from the rest of the device, you are ready to put in your new display.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Lashaun Noel
591 Reputatie
5 handleidingen geschreven
1Gids Commentaar
but can i ask do you know how to reboot the software ?
i mean we try to put in our music or video or image inside. can it be done
Nisha Najihah - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 29
Afgelopen 30 dagen: 53
Altijd: 699
