Ga door naar hoofdinhoud
Element GC-1020 Battery Replacement
Wat je nodig hebt
  1. Element GC-1020 Battery  Replacement, Back Cover Replacement Guide: stap 1, afbeelding 1 van 1
    • Unscrew the four screws (size: 3.175mm) on the left and right side of the Element Electronics GC-1020 device using the PH#0 screwdriver.
  2. Element GC-1020 Battery  Replacement: stap 2, afbeelding 1 van 1
    • Carefully pull the back of the device (the silver portion) apart from the rest of the device.
    • If you pull back too forcefully the power button would move out of place.
  3. Element GC-1020 Battery  Replacement, Battery: stap 3, afbeelding 1 van 2 Element GC-1020 Battery  Replacement, Battery: stap 3, afbeelding 2 van 2
    • Then remove the battery from the device through soldering the black and red wires connected to the motherboard.
    • This replacement will require a soldering station.
    • To find out more on soldering refer to the Soldering and Desolder page to help you through this process.
Conclusie
Lashaun Noel
591 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 314
