Ga door naar hoofdinhoud
Electric Eel Drain Cleaner Guide Spring Replacement
Wat je nodig hebt
    1. Electric Eel Drain Cleaner Guide Spring Replacement, Remove the Guide Spring: stap 1, afbeelding 1 van 3 Electric Eel Drain Cleaner Guide Spring Replacement, Remove the Guide Spring: stap 1, afbeelding 2 van 3 Electric Eel Drain Cleaner Guide Spring Replacement, Remove the Guide Spring: stap 1, afbeelding 3 van 3
      • Unplug your drain cleaner before starting this guide. Because this device may have been used in a septic setting, it should be cleaned and disinfected as much as possible before disassembly.
      • Wear gloves to protect your hands from injury when handling the cable.
      • Ensure the cable is completely retracted into the auto-feeder.
      • Twist the guide spring counter-clockwise to unscrew it from the auto-feeder.
      • Remove the guide spring.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Tarun Thiruma
40.486 Reputatie
134 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 46
Altijd: 860
