Ga door naar hoofdinhoud
Eightarc Fusion Joystick Replacement
Wat je nodig hebt
  1. Eightarc Fusion Joystick Replacement, Joystick: stap 1, afbeelding 1 van 2 Eightarc Fusion Joystick Replacement, Joystick: stap 1, afbeelding 2 van 2
    • Because of the protruding joystick on the top of the controller, make sure to work on a soft surface or prop the controller up to avoid stress on the joystick.
    • Place the controller face down (buttons and joystick down).
    • Use a Phillips Head #1 screwdriver to remove the eight 9.65mm screws located on the felt and metal backplate.
    • Do not confuse the four screws in the rubber feet with the eight screws in the felt. The screws in the feet do not need to be removed.
    Vraag FixBot
    Voeg opmerking toe
  2. Eightarc Fusion Joystick Replacement: stap 2, afbeelding 1 van 1
    • Open the door for the cord storage compartment on the right side of the device.
    • Reach under the panel and push upwards on the back panel. Lift it up and remove it from the device.
    Vraag FixBot
    Voeg opmerking toe
  3. Eightarc Fusion Joystick Replacement: stap 3, afbeelding 1 van 2 Eightarc Fusion Joystick Replacement: stap 3, afbeelding 2 van 2
    • Use the large plastic opening tool to softly pry the lip on the white 5 pin connector to relieve pressure while pulling the 5 pin connector.
    • Remove the white connector from the microswitch assembly.
    Vraag FixBot
    Voeg opmerking toe
  4. Eightarc Fusion Joystick Replacement: stap 4, afbeelding 1 van 2 Eightarc Fusion Joystick Replacement: stap 4, afbeelding 2 van 2
    • Insert a #4 Flat Head screwdriver into the shaft of the joystick and grasp the ball topper with your other hand.
    • Turn the flat head screwdriver counter clockwise for a quarter turn while tightly holding the ball topper.
    • The ball topper should now be loose enough to unscrew by hand.
    • Set aside the shaft cover, dust cover, and ball topper.
    Vraag FixBot
    Voeg opmerking toe
  5. Eightarc Fusion Joystick Replacement: stap 5, afbeelding 1 van 2 Eightarc Fusion Joystick Replacement: stap 5, afbeelding 2 van 2
    • Remove the four 8.35 mm screws from the mounting plate of the joystick using a Phillips Head #2 screwdriver.
    • Remove the joystick assembly from the controller.
    Vraag FixBot
    Voeg opmerking toe
  6. Eightarc Fusion Joystick Replacement: stap 6, afbeelding 1 van 3 Eightarc Fusion Joystick Replacement: stap 6, afbeelding 2 van 3 Eightarc Fusion Joystick Replacement: stap 6, afbeelding 3 van 3
    • Place joystick assembly on a hard, flat surface.
    • Gently press on the four black tabs on each side of the assembly.
    • With the tabs depressed, lift the clear restrictor plate from the assembly.
    Vraag FixBot
    Voeg opmerking toe
  7. Eightarc Fusion Joystick Replacement: stap 7, afbeelding 1 van 1
    • Remove the switch housing from the assembly by lifting straight up.
    • The joystick assembly is now ready to be replaced or cleaned.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Austin
245 Reputatie
2 handleidingen geschreven
Cal Poly, Team 17-35, Amido Winter 2015 Lid van Cal Poly, Team 17-35, Amido Winter 2015
CPSU-AMIDO-W15S17G35
4 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 61
Altijd: 1,380
