Ga door naar hoofdinhoud
Eightarc Fusion Button Replacement
Wat je nodig hebt
  1. Eightarc Fusion Button Replacement, Buttons: stap 1, afbeelding 1 van 1
    • Because of the protruding joystick on the top of the controller, make sure to work on a soft surface, or prop the controller up to avoid stress on the joystick.
    • Place the controller face down (buttons and joystick down).
    • Use a Phillips Head #1 screwdriver to remove the eight 9.65 mm screws located on the felt and metal backplate.
    • Do not confuse the four screws in the rubber feet with the eight screws in the felt. The screws in the feet do not need to be removed.
    Vraag FixBot
    Voeg opmerking toe
  2. Eightarc Fusion Button Replacement: stap 2, afbeelding 1 van 1
    • Open the door for the cord storage compartment on the right side of the device.
    • Reach under the panel and push upwards on the back panel. Lift it up and remove it from the device.
    Vraag FixBot
    Voeg opmerking toe
  3. Eightarc Fusion Button Replacement: stap 3, afbeelding 1 van 1
    • Remove the clear rubber casing around the wire connector by lifting the casing up and moving it up along the wire.
    • Repeat for second clear rubber casing.
    Vraag FixBot
    Voeg opmerking toe
  4. Eightarc Fusion Button Replacement: stap 4, afbeelding 1 van 2 Eightarc Fusion Button Replacement: stap 4, afbeelding 2 van 2
    • Gently grasp and lift up on the metal section of the wire to remove the wire from the button connector.
    • A slight wiggling motion might help remove the wire from the connector.
    • Make sure to keep track of which wires go to what button slot location.
    Vraag FixBot
    Voeg opmerking toe
  5. Eightarc Fusion Button Replacement: stap 5, afbeelding 1 van 2 Eightarc Fusion Button Replacement: stap 5, afbeelding 2 van 2
    • Gently depress the two plastic tabs on both of the sides of the button casing.
    • The plastic tabs on the buttons are extremely fragile, handle with care.
    • Slightly push the button down, out of the controller until it slides out.
    • During re-assembly, make sure the button tabs align with the slots in the casing when inserting the button back in.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Austin
245 Reputatie
2 handleidingen geschreven
Cal Poly, Team 17-35, Amido Winter 2015 Lid van Cal Poly, Team 17-35, Amido Winter 2015
CPSU-AMIDO-W15S17G35
4 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 28
Altijd: 1,143
