Inleiding
This guide is required when the device fails to power on and it has been determined that it is due to an issue with the battery. In order to replace the battery, soldering is required which is a safety hazard and requires specific equipment. When soldering, protective equipment should be worn and extreme caution should be taken.
Wat je nodig hebt
Using the screwdriver with the J00 bit, remove the two 4.8 mm Phillips screws.
Één andere persoon heeft deze handleiding voltooid.
