Ga door naar hoofdinhoud
Eclipse 180BL LCD Screen Cover Replacement
Wat je nodig hebt
    1. Eclipse 180BL LCD Screen Cover Replacement, LCD Screen Cover: stap 1, afbeelding 1 van 3 Eclipse 180BL LCD Screen Cover Replacement, LCD Screen Cover: stap 1, afbeelding 2 van 3 Eclipse 180BL LCD Screen Cover Replacement, LCD Screen Cover: stap 1, afbeelding 3 van 3
      • To start, remove the two screws located at the bottom of the device.
      • The two screws can be removed using the PH00 head located in the iFixit Repair ToolKit.
      • Both Screws are 1/8 inch in length.
      • Remove the case, and with the Spudger, apply force to the USB port to remove the inner component.
      • Be careful, as releasing the tension will cause all parts to become loose and separate.
      Vraag FixBot
      Voeg opmerking toe
    2. Eclipse 180BL LCD Screen Cover Replacement: stap 2, afbeelding 1 van 3 Eclipse 180BL LCD Screen Cover Replacement: stap 2, afbeelding 2 van 3 Eclipse 180BL LCD Screen Cover Replacement: stap 2, afbeelding 3 van 3
      • The LCD screen cover is placed into its slot after all the inner components are replaced.
      • Get the new screen cover, and carefully place in alignment with the outer shell.
      • Be sure that the screen fits perfectly, as dust getting in the screen will cause pixels to die.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Thomas Schwarz
499 Reputatie
3 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 38
Altijd: 955
