Inleiding
This guide demonstrates how to replace the camera's speaker.
Wat je nodig hebt
Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
Before removing back cover, it is advisable to use an anti-static wrist strap to prevent damage to electronics.
Remove all 7 screws:
Hold the camera firmly with one hand so that you can still see a screw.
Place the Philips 00(Found here)screwdriver into the screw.
Turn the screwdriver to the left until it is free.
Repeat for the remaining screws.
Open the battery door.
Press thumb firmly on battery door and slide it in the direction of the arrow.
Lift thumb allowing the door to swing open.
Locate the exposed portion of the LCD screen.
Use a wedge to free the LCD screen from the medal housing.
Remove the medal housing from the logic board by carefully peeling the yellow tape off of the metal housing.
Carefully pull the red and black wires located on the side of the camera connected to the speaker.
