Wat je nodig hebt
If you have any dust caps over the HDMI or Display Port connections, remove them
Remove the 3 screws using a Phillips #1 Screwdriver (Red)
Remove the 2 Standoffs using a 5mm socket
Gently slide the plate out from between the back cover and the circuit board. It should come out without much force.
If it doesn't want to budge, check that the right screw was removed from the top of the video card.
Bijna klaar!
Conclusie
