Ga door naar hoofdinhoud
Dyson V8 Absolute Battery Replacement
Wat je nodig hebt
  1. Dyson V8 Absolute Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Dyson V8 Absolute Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Detach wand from device.
    • Use a Phillips #2 screwdriver to unscrew the screw from the device handle.
    • Screw Head Type: Phillips #2
    • Screw Length: 170mm
    Vraag FixBot
    Voeg opmerking toe
  2. Dyson V8 Absolute Battery Replacement: stap 2, afbeelding 1 van 3 Dyson V8 Absolute Battery Replacement: stap 2, afbeelding 2 van 3 Dyson V8 Absolute Battery Replacement: stap 2, afbeelding 3 van 3
    • Turn device completely over to view battery pack.
    • Below the bin, use a Phillips #2 screwdriver to remove both screws from the battery pack.
    Vraag FixBot
    Voeg opmerking toe
  3. Dyson V8 Absolute Battery Replacement: stap 3, afbeelding 1 van 3 Dyson V8 Absolute Battery Replacement: stap 3, afbeelding 2 van 3 Dyson V8 Absolute Battery Replacement: stap 3, afbeelding 3 van 3
    • Pull the battery pack down and away from the device.
    • Battery pack may fall out.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
61 andere personen hebben deze handleiding voltooid.
Jasvir Dosanjh
1.959 Reputatie
1 Handleiding geschreven
UW Tacoma, Team S1-G5, Rose Fall 2017 Lid van UW Tacoma, Team S1-G5, Rose Fall 2017
UWT-ROSE-F17S1G5
4 Leden
16 handleidingen geschreven
18Gids Commentaar
Great instructions!!
akcosta60 - Antwoord Deel
I have replaced the battery and I still got a flashing red light, any ideas
georgewaterson - Antwoord Deel
I replaced my battery and charged the new one- my vac doesnt work
grooveon.g - Antwoord Deel
if you have got the switch on max slide other way plug it to charge for 3,4 minuite then try should work. do not put on max as it will not work and you will have to do it all over again
anthony richards - Antwoord Deel
My v8 animal has a new battery but it doesn't seem to want to charge. The 1st of the 3 battery lights lights up constantly, the 2nd just flashes and the 3rd never lights up no matter how long it's left on charge. The motor will run ok on the lower setting but cut's out almost instantly in the highest setting.
Could the charger be at fault?
Trunker Trubshaw - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 60
Afgelopen 7 dagen: 418
Afgelopen 30 dagen: 1,731
Altijd: 215,041
