Ga door naar hoofdinhoud
Dyson Supersonic HD01 Buttons Replacement
Wat je nodig hebt
  1. Dyson Supersonic HD01 Buttons Replacement, Buttons: stap 1, afbeelding 1 van 2 Dyson Supersonic HD01 Buttons Replacement, Buttons: stap 1, afbeelding 2 van 2
    • Heat the iOpener in the microwave for 30 seconds and apply it immediately to the top of the buttons.
    • Leave the iOpener in place for a couple minutes.
    Vraag FixBot
    Voeg opmerking toe
  2. Dyson Supersonic HD01 Buttons Replacement: stap 2, afbeelding 1 van 3 Dyson Supersonic HD01 Buttons Replacement: stap 2, afbeelding 2 van 3 Dyson Supersonic HD01 Buttons Replacement: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Microfiber Cleaning Cloths
    $3.99
    • Remove the buttons with tweezers.
    • Power button
    • Cold shot button
    • Use a microfiber towel soaked in rubbing alcohol to clean the button holes. Doing this will loosen the buttons if jammed.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Sophie Windover
379 Reputatie
2 handleidingen geschreven
Utah Tech University, Team 1-5, McMurrin Fall 2022 Lid van Utah Tech University, Team 1-5, McMurrin Fall 2022
UTAHTECH-MCMURRIN-F22S1G5
3 Leden
9 handleidingen geschreven
2Gids Commentaar
My Dyson Supersonic will start but nor heat up. Called the company but guarantee expired by 3 months. They won't fix it.
Is there a chance to check inside and try to repair? Thanks.
mario enrico rosati - Antwoord Deel
as far as I know only counterfit supersonics fail in that way. I had one of those. The inrush current limiter basically exploded. (because the part is sized way too small for the current in a hair dryer). Real dysons usually stop working alltogether because the thermal fuse blew.
karatektus - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 46
Afgelopen 30 dagen: 233
Altijd: 9,826
