Ga door naar hoofdinhoud
Dyson DC56 Cyclone Replacement
Wat je nodig hebt
    1. Dyson DC56 Cyclone Replacement, Dust Bin: stap 1, afbeelding 1 van 1
      • Make sure the vacuum is unplugged.
      • Warning: Avoid pressing the red trigger because it will turn on and begin suction.
      Vraag FixBot
      Voeg opmerking toe
    2. Dyson DC56 Cyclone Replacement: stap 2, afbeelding 1 van 1
      • Locate the purple button at the top of the device.
      Vraag FixBot
      Voeg opmerking toe
    3. Dyson DC56 Cyclone Replacement: stap 3, afbeelding 1 van 1
      • Separate the device with the purple button.
      Vraag FixBot
      Voeg opmerking toe
    4. Dyson DC56 Cyclone Replacement: stap 4, afbeelding 1 van 1
      • Locate the dust bin's red release lever on the side of the device.
      • Make sure if the dust bin is full you open the vacuum over a trash can.
      Vraag FixBot
      Voeg opmerking toe
    5. Dyson DC56 Cyclone Replacement: stap 5, afbeelding 1 van 1
      • Push the red lever to release the dust bin lid.
      Vraag FixBot
      Voeg opmerking toe
    6. Dyson DC56 Cyclone Replacement: stap 6, afbeelding 1 van 1
      • Locate the red lever below the vacuum.
      Vraag FixBot
      Voeg opmerking toe
    7. Dyson DC56 Cyclone Replacement: stap 7, afbeelding 1 van 1
      • Push the red lever, pull the back up and away from the dust bin to separate them.
      Vraag FixBot
      Voeg opmerking toe
    1. Dyson DC56 Cyclone Replacement, Cyclone: stap 8, afbeelding 1 van 1
      • Use a T8-Torque screwdriver to remove the 18mm screw from the back of the Cyclone.
      Vraag FixBot
      Voeg opmerking toe
    2. Dyson DC56 Cyclone Replacement: stap 9, afbeelding 1 van 1
      • Remove the bottom of the cyclone screen by twisting it to the left and pulling down.
      Vraag FixBot
      Voeg opmerking toe
    3. Dyson DC56 Cyclone Replacement: stap 10, afbeelding 1 van 1
      • Remove the rest of the cyclone screen by pulling down.
      Vraag FixBot
      Voeg opmerking toe
    4. Dyson DC56 Cyclone Replacement: stap 11, afbeelding 1 van 1
      • Locate and take out the six 26mm screws with a T-8 Torque screwdriver.
      • Once you have removed the screws you can remove the rest of the Cyclone.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
John Czerkawski
427 Reputatie
4 handleidingen geschreven
USF Tampa, Team S10-G1, Thompson Fall 2017 Lid van USF Tampa, Team S10-G1, Thompson Fall 2017
USFT-THOMPSON-F17S10G1
4 Leden
16 handleidingen geschreven
1Gids Commentaar
I can’t remove the cyclone screen. Any tricks to removing?
J M - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 34
Altijd: 1,336
