Ga door naar hoofdinhoud
Dyson DC39 Origin Cyclone Filter Replacement
Wat je nodig hebt
  1. Dyson DC39 Origin Cyclone Filter Replacement, Bin: stap 1, afbeelding 1 van 3 Dyson DC39 Origin Cyclone Filter Replacement, Bin: stap 1, afbeelding 2 van 3 Dyson DC39 Origin Cyclone Filter Replacement, Bin: stap 1, afbeelding 3 van 3
    • Push down on the gray button located next to the power button to release the bin from the ball housing.
    • Pull the bin away, then up from the ball housing to remove it.
    • If the bin won't fit back into place during re-assembly, you may need to push the grey button again.
    Vraag FixBot
    Voeg opmerking toe
  2. Dyson DC39 Origin Cyclone Filter Replacement, Pre-filter: stap 2, afbeelding 1 van 3 Dyson DC39 Origin Cyclone Filter Replacement, Pre-filter: stap 2, afbeelding 2 van 3 Dyson DC39 Origin Cyclone Filter Replacement, Pre-filter: stap 2, afbeelding 3 van 3
    • Remove the purple pre-filter by pulling it up and out of the bin.
    Vraag FixBot
    Voeg opmerking toe
  3. Dyson DC39 Origin Cyclone Filter Replacement, Cyclone Filter: stap 3, afbeelding 1 van 2 Dyson DC39 Origin Cyclone Filter Replacement, Cyclone Filter: stap 3, afbeelding 2 van 2
    • Push down on the red button, located on top of the bin, to release the bottom section of the bin.
    Vraag FixBot
    Voeg opmerking toe
  4. Dyson DC39 Origin Cyclone Filter Replacement: stap 4, afbeelding 1 van 1
    • Push the grey button located in between the parts of the red lever to release the clear, bottom section of the bin.
    • The grey button can only be pressed after the bottom section is open.
    Vraag FixBot
    Voeg opmerking toe
  5. Dyson DC39 Origin Cyclone Filter Replacement: stap 5, afbeelding 1 van 3 Dyson DC39 Origin Cyclone Filter Replacement: stap 5, afbeelding 2 van 3 Dyson DC39 Origin Cyclone Filter Replacement: stap 5, afbeelding 3 van 3
    • You should notice several notches around the rim of the filter. Slide the plastic opening tool around the rim to release the notches.
    • After releasing all of the notches, pull the filter away from the orange cyclone assembly to remove it from the bin.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Sam Nelson
167 Reputatie
1 Handleiding geschreven
Cal Poly, Team S23-G6, Livingston Spring 2017 Lid van Cal Poly, Team S23-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G6
3 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 40
Altijd: 4,011
