Ga door naar hoofdinhoud
Dyson DC39 Origin Ball Wheels Replacement
Wat je nodig hebt
    1. Dyson DC39 Origin Ball Wheels Replacement, Bin: stap 1, afbeelding 1 van 3 Dyson DC39 Origin Ball Wheels Replacement, Bin: stap 1, afbeelding 2 van 3 Dyson DC39 Origin Ball Wheels Replacement, Bin: stap 1, afbeelding 3 van 3
      • Push down on the gray button located next to the power button to release the bin from the ball housing.
      • Pull the bin away, then up from the ball housing to remove it.
      • If the bin won't fit back into place during re-assembly, you may need to push the grey button again.
      Vraag FixBot
      Voeg opmerking toe
    1. Dyson DC39 Origin Ball Wheels Replacement, Steering Assembly: stap 2, afbeelding 1 van 3 Dyson DC39 Origin Ball Wheels Replacement, Steering Assembly: stap 2, afbeelding 2 van 3 Dyson DC39 Origin Ball Wheels Replacement, Steering Assembly: stap 2, afbeelding 3 van 3
      • Place the ball housing on its side and orient it so that the underside of the steering assembly is facing you.
      • Remove the four 18.0 mm Torx 15 screws.
      Vraag FixBot
      Voeg opmerking toe
    2. Dyson DC39 Origin Ball Wheels Replacement: stap 3, afbeelding 1 van 3 Dyson DC39 Origin Ball Wheels Replacement: stap 3, afbeelding 2 van 3 Dyson DC39 Origin Ball Wheels Replacement: stap 3, afbeelding 3 van 3
      • Using two hands, hold the ball housing with the handle in one hand and the steering assembly base in the other.
      • Hold the steering assembly base near one of the wheels.
      • Pull the steering assembly base directly away from the ball housing. You should notice a pin release.
      • Push up on the steering assembly to remove it completely from the ball housing.
      • During reassembly, slide the steering assembly in first, then push the pin back into its locking position.
      Vraag FixBot
      Voeg opmerking toe
    1. Dyson DC39 Origin Ball Wheels Replacement, Ball Wheels: stap 4, afbeelding 1 van 2 Dyson DC39 Origin Ball Wheels Replacement, Ball Wheels: stap 4, afbeelding 2 van 2
      • Remove the 21.4 mm Torx 15 screw located at the center of the ball wheel.
      • There is one screw located at the center of each wheel.
      Vraag FixBot
      Voeg opmerking toe
    2. Dyson DC39 Origin Ball Wheels Replacement: stap 5, afbeelding 1 van 3 Dyson DC39 Origin Ball Wheels Replacement: stap 5, afbeelding 2 van 3 Dyson DC39 Origin Ball Wheels Replacement: stap 5, afbeelding 3 van 3
      • Pull the wheel away from the main body of the device.
      • This may require a lot of force. The plastic wheel may bend slightly.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Michael Hutcheson
312 Reputatie
2 handleidingen geschreven
Cal Poly, Team S23-G6, Livingston Spring 2017 Lid van Cal Poly, Team S23-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G6
3 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 26
Altijd: 2,659
