Ga door naar hoofdinhoud
Dyson DC39 Origin Replacement
Wat je nodig hebt
  1. Dyson DC39 Origin  Replacement, Bin: stap 1, afbeelding 1 van 3 Dyson DC39 Origin  Replacement, Bin: stap 1, afbeelding 2 van 3 Dyson DC39 Origin  Replacement, Bin: stap 1, afbeelding 3 van 3
    • Push down on the gray button located next to the power button to release the bin from the ball housing.
    • Pull the bin away, then up from the ball housing to remove it.
    • If the bin won't fit back into place during re-assembly, you may need to push the grey button again.
    Vraag FixBot
    Voeg opmerking toe
  2. Dyson DC39 Origin  Replacement, Steering Assembly: stap 2, afbeelding 1 van 3 Dyson DC39 Origin  Replacement, Steering Assembly: stap 2, afbeelding 2 van 3 Dyson DC39 Origin  Replacement, Steering Assembly: stap 2, afbeelding 3 van 3
    • Place the ball housing on its side and orient it so that the underside of the steering assembly is facing you.
    • Remove the four 18.0 mm Torx 15 screws.
    Vraag FixBot
    Voeg opmerking toe
  3. Dyson DC39 Origin  Replacement: stap 3, afbeelding 1 van 3 Dyson DC39 Origin  Replacement: stap 3, afbeelding 2 van 3 Dyson DC39 Origin  Replacement: stap 3, afbeelding 3 van 3
    • Using two hands, hold the ball housing with the handle in one hand and the steering assembly base in the other.
    • Hold the steering assembly base near one of the wheels.
    • Pull the steering assembly base directly away from the ball housing. You should notice a pin release.
    • Push up on the steering assembly to remove it completely from the ball housing.
    • During reassembly, slide the steering assembly in first, then push the pin back into its locking position.
    Vraag FixBot
    Voeg opmerking toe
  4. Dyson DC39 Origin  Replacement, Inlet Hose: stap 4, afbeelding 1 van 2 Dyson DC39 Origin  Replacement, Inlet Hose: stap 4, afbeelding 2 van 2
    • Remove the two 17.8 mm Phillips #2 screws located in the top of the inlet hose bracket.
    • Remove the two 13.7 mm Torx 8 screws located at the opposite end of the inlet hose.
    • The Torx 8 screws are located at an odd angle. Be sure the screwdriver is secure to prevent stripping the screws.
    Vraag FixBot
    Voeg opmerking toe
  5. Dyson DC39 Origin  Replacement: stap 5, afbeelding 1 van 2 Dyson DC39 Origin  Replacement: stap 5, afbeelding 2 van 2
    • Pull the inlet hose straight up from the steering assembly.
    • The inlet hose 'snaps' out of its position, so you may have to apply a little extra force while pulling.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
Michael Hutcheson
312 Reputatie
2 handleidingen geschreven
Cal Poly, Team S23-G6, Livingston Spring 2017 Lid van Cal Poly, Team S23-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G6
3 Leden
12 handleidingen geschreven
1Gids Commentaar
Really clear instructions - thank you
collette - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 32
Altijd: 4,789
