Inleiding
Follow this guide to replace the battery on a Sony DualShock 4 CHU-ZCT2U Playstation controller.
This guide will also work for the older CHU-ZCT1U model controller but be sure to order the JDM-030 battery, which has a different sized connector. You can check which model controller you have by referencing the sticker on the rear panel.
If your battery is swollen, take appropriate precautions.
Wat je nodig hebt
Use a Phillips screwdriver to remove the four 6.4 mm-long screws from the rear panel.
Insert an opening tool into the crease where the front and rear panel meet, starting from the outside edge of either handle.
Gently pry the rear panel off of the front panel until they become partially separated.
Use the opening tool to separate the panels by releasing the plastic clips around the perimeter of the controller.
Use a pair of tweezers to pull the battery's power connector straight up from the motherboard.
24 andere personen hebben deze handleiding voltooid.
3 opmerkingen
For this DualShock 4 CHU-ZCT2U Battery Replacement, shouldn’t the battery model be JDM-040 and not JDM-030 for this controller. I ordered the battery listed but the connector was too large. So I believe this needs to be edited to match accordingly to avoid confusion and incorrect orders. Thanks!
Good catch! I just pulled apart the ZCT1U and ZCT2U models and you are right. I will fix this in the guide. Thank you!
