Ga door naar hoofdinhoud
DualShock 3 Front Shell Cover Replacement
Wat je nodig hebt
  1. DualShock 3 Front Shell Cover Replacement, Front Shell Cover.: stap 1, afbeelding 1 van 2 DualShock 3 Front Shell Cover Replacement, Front Shell Cover.: stap 1, afbeelding 2 van 2
    • Flip the controller over and locate the five 7.2mm Phillips #0 screws securing the rear cover to the front cover.
    Vraag FixBot
    Voeg opmerking toe
  2. DualShock 3 Front Shell Cover Replacement: stap 2, afbeelding 1 van 3 DualShock 3 Front Shell Cover Replacement: stap 2, afbeelding 2 van 3 DualShock 3 Front Shell Cover Replacement: stap 2, afbeelding 3 van 3
    • Using the Phillips #0 screwdriver, remove the five screws holding the rear/back cover in place.
    Vraag FixBot
    Voeg opmerking toe
  3. DualShock 3 Front Shell Cover Replacement: stap 3, afbeelding 1 van 2 DualShock 3 Front Shell Cover Replacement: stap 3, afbeelding 2 van 2
    • Gently lift the rear cover away from the rest of the controller starting from the bottom side adjacent to the analog stick controllers.
    • Push gently by sliding the rear back forward towards the top edge of the dual shock controller to prevent tripping the two bottom triggers labelled (2).
    Vraag FixBot
    Voeg opmerking toe
  4. DualShock 3 Front Shell Cover Replacement: stap 4, afbeelding 1 van 1
    • Lift the rear cover off of the controller to expose the interior.
    Vraag FixBot
    Voeg opmerking toe
  5. DualShock 3 Front Shell Cover Replacement: stap 5, afbeelding 1 van 3 DualShock 3 Front Shell Cover Replacement: stap 5, afbeelding 2 van 3 DualShock 3 Front Shell Cover Replacement: stap 5, afbeelding 3 van 3
    • Carefully detach or disconnect the lithium polymer battery from the motherboard.
    • The wires are fragile, be careful not to break them when pulling out the battery as they can break easily.
    Vraag FixBot
    Voeg opmerking toe
  6. DualShock 3 Front Shell Cover Replacement: stap 6, afbeelding 1 van 3 DualShock 3 Front Shell Cover Replacement: stap 6, afbeelding 2 van 3 DualShock 3 Front Shell Cover Replacement: stap 6, afbeelding 3 van 3
    • Use the Phillips #0 screwdriver to remove five 7.2 mm screws from the motherboard.
    • Lift the motherboard, vibration motors and analog module joysticks pads all in one connection, away from the shell.
    Vraag FixBot
    Voeg opmerking toe
  7. DualShock 3 Front Shell Cover Replacement: stap 7, afbeelding 1 van 2 DualShock 3 Front Shell Cover Replacement: stap 7, afbeelding 2 van 2
    • Carefully lift the rubber or plastic part holding the button triggers labelled (2) in place.
    • Be careful not to strip the plastic rubber holding the triggers in place.
    • Slide the trigger button retainers away from the front shell. Set them aside.
    Vraag FixBot
    Voeg opmerking toe
  8. DualShock 3 Front Shell Cover Replacement: stap 8, afbeelding 1 van 1
    • Set aside the colored buttons and lift the white rubber part holding the Dpad buttons in place to securely remove it.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Joseph Wambui
253 Reputatie
1 Handleiding geschreven
York University, Team 1-28, O'Regan Fall 2021 Lid van York University, Team 1-28, O'Regan Fall 2021
YORK-O'REGAN-F21S1G28
1 Lid
3 handleidingen geschreven
1Gids Commentaar
The original 6 axis controller I got with my PS3 back in the day has different size screws than the gold plated one I got a few years later. They're about 3 mm longer too
Gregory Hedges - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 55
Afgelopen 30 dagen: 244
Altijd: 7,831
