Ga door naar hoofdinhoud
DualShock 3 Buttons Replacement
Wat je nodig hebt
  1. DualShock 3 Buttons Replacement, Rear Cover: stap 1, afbeelding 1 van 1
    • Remove the five 7.2 mm Phillips screws securing the rear cover to the controller.
    Vraag FixBot
    Voeg opmerking toe
  2. DualShock 3 Buttons Replacement: stap 2, afbeelding 1 van 1
    • Press on the rear cover between the analog sticks and slightly lift the lower edge of it away from the rest of the controller.
    Vraag FixBot
    Voeg opmerking toe
  3. DualShock 3 Buttons Replacement: stap 3, afbeelding 1 van 2 DualShock 3 Buttons Replacement: stap 3, afbeelding 2 van 2
    • Push the rear cover slightly toward the top edge of the controller to clear the front edge of the #2 triggers.
    • Pull the rear cover away from the rest of the controller, being careful not to pop off the #2 triggers.
    • If you happen to accidentally pop off the trigger buttons, we have a trigger button guide to reattach them.
    Vraag FixBot
    Voeg opmerking toe
  4. DualShock 3 Buttons Replacement, Battery: stap 4, afbeelding 1 van 1
    • Lift the battery off the motherboard for enough clearance to access the battery connector.
    Vraag FixBot
    Voeg opmerking toe
  5. DualShock 3 Buttons Replacement: stap 5, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Carefully pull the battery connector away from its socket on the motherboard.
    • It may be helpful to use a pair of tweezers or pliers to grab the battery connector when you disconnect it for the first time. Only pull on the connector. Do not try to remove by pulling on the red and black wires.
    Vraag FixBot
    Voeg opmerking toe
  6. DualShock 3 Buttons Replacement, Motherboard Assembly: stap 6, afbeelding 1 van 1
    • Remove the single 7.2 mm Phillips screw securing the motherboard to the front cover.
    Vraag FixBot
    Voeg opmerking toe
  7. DualShock 3 Buttons Replacement: stap 7, afbeelding 1 van 3 DualShock 3 Buttons Replacement: stap 7, afbeelding 2 van 3 DualShock 3 Buttons Replacement: stap 7, afbeelding 3 van 3
    • Slide the trigger button retainers slightly away from the front cover.
    • Remove the #1 button on both sides.
    Vraag FixBot
    Voeg opmerking toe
  8. DualShock 3 Buttons Replacement: stap 8, afbeelding 1 van 2 DualShock 3 Buttons Replacement: stap 8, afbeelding 2 van 2
    • Pull the vibration motor retainers away from the front cover to dislodge the motherboard assembly.
    Vraag FixBot
    Voeg opmerking toe
  9. DualShock 3 Buttons Replacement: stap 9, afbeelding 1 van 1
    • Remove the motherboard assembly from the front cover.
    • When removing the motherboard assembly, try not to tilt the front cover upside down as the buttons and their covers may fall out.
    Vraag FixBot
    Voeg opmerking toe
  10. DualShock 3 Buttons Replacement, Buttons: stap 10, afbeelding 1 van 2 DualShock 3 Buttons Replacement, Buttons: stap 10, afbeelding 2 van 2
    • Lift the rubber button contacts off the front controller cover to access the plastic button covers.
    • Lift any damaged plastic button covers out of the controller cover.
    Vraag FixBot
    Voeg opmerking toe
  11. DualShock 3 Buttons Replacement: stap 11, afbeelding 1 van 1
    • The D-pad has a three-armed plastic piece that must be installed as shown before installing the rubber button pad for it to work properly.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
109 andere personen hebben deze handleiding voltooid.
6Gids Commentaar
My Dualshock 3 didn't have the three armed plastic piece on the D-pad. Mine's a red one, relatively recent. My controller also had the problem where it would randomly send button press events when using the L-stick. I traced the problem to the ribbon connector between the board and the contacts, which was very dirty. I cleaned the contacts and put the controller back together with an additional rubber shim between the back cover and the battery, which got rid of the creakiness of the somewhat loose-fitting case. Works great now.
Kevin - Antwoord Deel
How do you clean the contacts? Is there a special way?
yeshuabendavid - Antwoord Deel
Thanks. ^^ Tightened screws after opening it and this kind of problem got solved.
Janne K - Antwoord Deel
Are these instructions the same for the dual-shock 2?
Larry Howard - Antwoord Deel
TNX-could not really figure out where the 3-armed plastic should fit in but tnx to step 11 i know-now im going to dismantle my controller again.
Kristian Brandström - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 17
Afgelopen 7 dagen: 128
Afgelopen 30 dagen: 537
Altijd: 173,271
