Inleiding
For this repair I replaced the LCD and Digitizer that comes with a frame. When ordering the part you should make sure it has the frame, because if you repair the front assembly without the frame, there will always be a slight lift in the screen. If you repair it without the frame it will still work, but you will run the risk of cracking the screen again due to that slight lift.
Wat je nodig hebt
Start by removing the Sim card tray, which also happens to be your volume button
I personally used an iSesamo tool to unclip the tabs off the back housing, You can also use the Jimmy or some plastic prying tools.
Do Not pry the back housing around the bottom of the screen. Pry on the left, right, and top. After that the back housing should slide off on the bottom.
.... as long as you work your way backwards to put it back together.
17 andere personen hebben deze handleiding voltooid.
8Gids Commentaar
I want to repair the scencor
I want to repair the XT1080 sciencer
Repair screen on droid ultra XT 1080
My Android 1080 screen is frozen. How can I get my photos?
My Android 1080 is frozen. How can I retrieve my pictures?
As long as your phone is on and working, you should be able to connect your phone to your laptop and use it as if it were an external hard drive.
