Ga door naar hoofdinhoud
Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement
Wat je nodig hebt
  1. Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement, Battery: stap 1, afbeelding 1 van 3 Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement, Battery: stap 1, afbeelding 2 van 3 Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement, Battery: stap 1, afbeelding 3 van 3
    • Pull back on the release tabs to disconnect the battery pack from the housing.
    • When installing a new battery, you may need to charge it before using it.
  2. Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement, Motor-Shaft Assembly: stap 2, afbeelding 1 van 3 Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement, Motor-Shaft Assembly: stap 2, afbeelding 2 van 3 Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement, Motor-Shaft Assembly: stap 2, afbeelding 3 van 3
    • Remove the two screws from the back of the device with the TR10 Torx Security screwdriver.
    • Make sure you have removed the battery before proceeding as accidentally powering-on the device while disassembling is dangerous due to the high-speed components inside.
  3. Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement: stap 3, afbeelding 1 van 3 Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement: stap 3, afbeelding 2 van 3 Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement: stap 3, afbeelding 3 van 3
    • Lift off the unscrewed plastic cover at an angle, away from the tip of the device.
    • Gently lift the cover. It won't take much force to remove it.
  4. Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement: stap 4, afbeelding 1 van 3 Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement: stap 4, afbeelding 2 van 3 Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement: stap 4, afbeelding 3 van 3
    • Lift the tip of the motor-shaft assembly gently, then pull the assembly out.
    • The blue battery contact and the spring for the shaft lock button may pop out when you remove the motor-shaft assembly. Make sure to keep track of these pieces, as they are very small.
  5. Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement, Shaft Lock Assembly: stap 5, afbeelding 1 van 1
    • There are two pieces that make up the shaft lock assembly:
    • The key.
    • The wire ring.
    • The key holds the wire ring in place, and the wire ring secures the motor shaft.
  6. Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement: stap 6, afbeelding 1 van 3 Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement: stap 6, afbeelding 2 van 3 Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement: stap 6, afbeelding 3 van 3
    • Remove the wire ring from the device.
    • The wire ring may have come out when the motor-shaft assembly was removed.
    • Remove the key from its slot.
  7. Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement: stap 7, afbeelding 1 van 2 Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement: stap 7, afbeelding 2 van 2
    • Ensure that the shaft lock assembly fits together properly when reassembling the device.
    • The notch in the wire ring should fit on the key as pictured.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Kat
840 Reputatie
3 handleidingen geschreven
USF Tampa, Team 3-4, Sullivan Spring 2016 Lid van USF Tampa, Team 3-4, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G4
4 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 1,825
