Ga door naar hoofdinhoud
Dremel 7300 MiniMite Cordless Collet Replacement
Wat je nodig hebt
    1. Dremel 7300 MiniMite Cordless Collet Replacement, Collet: stap 1, afbeelding 1 van 3 Dremel 7300 MiniMite Cordless Collet Replacement, Collet: stap 1, afbeelding 2 van 3 Dremel 7300 MiniMite Cordless Collet Replacement, Collet: stap 1, afbeelding 3 van 3
      • The device comes with a small black wrench to tighten the collet nut, during reassembly or changing the bits.
      • Press the blue button and hold it down.
      • Unscrew the collet nut, with your fingers (as if you were going to change the bit).
      • Continue until the collet nut comes completely off of the Dremel.
      Vraag FixBot
      Voeg opmerking toe
    2. Dremel 7300 MiniMite Cordless Collet Replacement: stap 2, afbeelding 1 van 3 Dremel 7300 MiniMite Cordless Collet Replacement: stap 2, afbeelding 2 van 3 Dremel 7300 MiniMite Cordless Collet Replacement: stap 2, afbeelding 3 van 3
      • Once the collet nut is off, you can remove the collet. It is the silver part that grips the bit when the collet nut tightens on it.
      • The collet itself may be in the shaft, or come off with the nut.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
7 andere personen hebben deze handleiding voltooid.
Kat
864 Reputatie
3 handleidingen geschreven
USF Tampa, Team 3-4, Sullivan Spring 2016 Lid van USF Tampa, Team 3-4, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G4
4 Leden
12 handleidingen geschreven
2Gids Commentaar
Too anyone having trouble unscrewing the collet, you may want to clamp vice grips on if its stuck tight. Worked for me.
Will - Antwoord Deel
I easily removed the bit by holding the blue button and using the black wrench to loosen it and then I remove the silver piece that holds the bit then when I tried to use another one of the attachments it seems like it’s too large to fit in there I haven’t been able to use any of the other attachments like polishing and the finer little grinders
Kate Denkers - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 33
Altijd: 33,165
