Ga door naar hoofdinhoud
Dremel 4000 Shaft Lock Pin Replacement
Wat je nodig hebt
    1. Dremel 4000 Shaft Lock Pin Replacement, Back Case: stap 1, afbeelding 1 van 2 Dremel 4000 Shaft Lock Pin Replacement, Back Case: stap 1, afbeelding 2 van 2
      • Start by removing the housing cap by unscrewing it.
      • Next, unscrew the now exposed collet nut while holding down the shaft lock button.
      • To remove the collet nut, you may need to use the small open-end wrench provided with the Dremel.
      Vraag FixBot
      Voeg opmerking toe
    2. Dremel 4000 Shaft Lock Pin Replacement: stap 2, afbeelding 1 van 1
      • Using your hands, carefully remove hanger from casing.
      Vraag FixBot
      Voeg opmerking toe
    3. Dremel 4000 Shaft Lock Pin Replacement: stap 3, afbeelding 1 van 2 Dremel 4000 Shaft Lock Pin Replacement: stap 3, afbeelding 2 van 2
      • Remove the brush caps (one on each side) by using a flathead screwdriver bit.
      • The brush caps are spring loaded.
      Vraag FixBot
      Voeg opmerking toe
    4. Dremel 4000 Shaft Lock Pin Replacement: stap 4, afbeelding 1 van 1
      • Using the Torx 15 screwdriver tip, remove the 5 screws (12.5 mm) that hold the casing together.
      Vraag FixBot
      Voeg opmerking toe
    5. Dremel 4000 Shaft Lock Pin Replacement: stap 5, afbeelding 1 van 1
      • Use a plastic opening tool to gently wedge apart the hard plastic threads.
      Vraag FixBot
      Voeg opmerking toe
    6. Dremel 4000 Shaft Lock Pin Replacement: stap 6, afbeelding 1 van 1
      • Use your hands to carefully remove the back casing so that none of the components fall out.
      Vraag FixBot
      Voeg opmerking toe
    1. Dremel 4000 Shaft Lock Pin Replacement, Shaft Lock Pin: stap 7, afbeelding 1 van 1
      • If the shaft lock pin is not engaging the rotary gear, or if the spring is missing or damaged, it will need to be replaced.
      • Remove the damaged shaft lock pin and spring by hand.
      • Place new shaft lock pin so that the spring functions and the lock engages the rotary gear.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
John Cobb
1.842 Reputatie
4 handleidingen geschreven
USF Tampa, Team 15-4, Remmell Spring 2016 Lid van USF Tampa, Team 15-4, Remmell Spring 2016
USFT-REMMELL-S16S15G4
4 Leden
17 handleidingen geschreven
3Gids Commentaar
These instructions are idiotic! I want to replace the shaft lock pin because it is not WORKING. Step 1 instructs me to use the shaft lock pin to remove the exposed collet nut. The reason I am changing the shaft lock pin is because it won’t hold the shaft for loosening the collet nut. DUH!
mitchthane - Antwoord Deel
three years later and I came to the same conclusion: DUH
Randy Martin - Antwoord Deel
Four years later and I came to the same conclusion: DUH
Ben simon - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 106
Altijd: 16,304
