Ga door naar hoofdinhoud
Dreamax DMX-ST7A Motherboard Replacement
Wat je nodig hebt
  1. Dreamax DMX-ST7A Motherboard Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Position the tablet so the ports and screws are facing you.
  2. Dreamax DMX-ST7A Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 2.5mm screws using the Phillips #00 precision screwdriver.
  3. Dreamax DMX-ST7A Motherboard Replacement: stap 3, afbeelding 1 van 2 Dreamax DMX-ST7A Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Use the plastic opening tool to assist in removing the back cover.
  4. Dreamax DMX-ST7A Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Upon removing the back cover position the tablet as seen in the picture.
  5. Dreamax DMX-ST7A Motherboard Replacement, Motherboard: stap 5, afbeelding 1 van 2 Dreamax DMX-ST7A Motherboard Replacement, Motherboard: stap 5, afbeelding 2 van 2
    • Lift the black bars to expose the data strips.
    • Remove the data strips.
  6. Dreamax DMX-ST7A Motherboard Replacement: stap 6, afbeelding 1 van 2 Dreamax DMX-ST7A Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Remove the three 2.5mm screws using the Phillips #00 precision screwdriver that is holding the motherboard in place.
  7. Dreamax DMX-ST7A Motherboard Replacement: stap 7, afbeelding 1 van 2 Dreamax DMX-ST7A Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Remove the three wires connected to the battery along with the speaker wires from the motherboard. Then remove the motherboard from the tablet.
  8. Dreamax DMX-ST7A Motherboard Replacement: stap 8, afbeelding 1 van 2 Dreamax DMX-ST7A Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Install the new motherboard by soldering the speaker wires and the battery wires in their intended location. For additional soldering instructions please view this page: Hoe moet je (de-)solderen?
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Stacey Mattila
543 Reputatie
5 handleidingen geschreven
Michigan Tech, Team 1-4, Lauer Spring 2015 Lid van Michigan Tech, Team 1-4, Lauer Spring 2015
MTU-LAUER-S15S1G4
2 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 321
