Ga door naar hoofdinhoud
Dragon Touch Y88X Plus Motherboard Replacement
Wat je nodig hebt
  1. Dragon Touch Y88X Plus Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Remove the back case using a plastic opening tool or spudger.
    • Start at the corners and work your way around the perimeter of the tablet.
    • Be gentle to avoid damaging the case or any internal components.
  2. Dragon Touch Y88X Plus Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove any adhesive strips keeping wires in place.
  3. Dragon Touch Y88X Plus Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Desolder the wires connected to the motherboard to disconnect the battery and speaker.
  4. Dragon Touch Y88X Plus Motherboard Replacement: stap 4, afbeelding 1 van 2 Dragon Touch Y88X Plus Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Use the tip of a spudger or your fingernail to flip up the small locking flap on the three ZIF connectors.
    • Be sure to pry up on the hinged flap, not the connector socket.
    • Use a spudger to slide the ribbon cables from the connectors.
  5. Dragon Touch Y88X Plus Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the three 4 mm screws from the edges of the motherboard.
  6. Dragon Touch Y88X Plus Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Gently lift the motherboard from the device.
Conclusie
Cody Camara
149 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 1-4, Petersen Fall 2023 Lid van UMass Dartmouth, Team 1-4, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G4
4 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 69
