Inleiding
We are going to teach an individual to change the battery on their tablet should they have an issue with the device's battery.
Wat je nodig hebt
Remove the two screws from the top of the tablet as shown in the figure using a J0 philips head bit.
Use the large plastic opening tool to separate the back cover from the device. Wedge the sharp end of the tool into the crack and use leverage to further separate the back cover from the device.
Still holding pressure on the opening tool, slowly and carefully slide the tool along the gap to separate it further. You should hear slight snapping as it comes apart. Work your way around all sides until the cover is able to be removed.
This is the most difficult part. The battery is held onto the surface with a strong epoxy. The battery can be bent easily so extreme care must be taken in removing it from the surface. A plastic opening tool must be used to loosen the battery from the surface.
Once it is loose, it may be fully separated by using either your hands or the plastic opening tool.
The red and white wires connecting the battery to the motherboard must be desoldered. Refer to the Soldering Technique Guide for instructions on how to do this. (Be sure to desolder the wires from the battery AND the motherboard.)
3 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Why desolder the wires from the motherboard? Couldn't you just solder them to the new battery while they're still attached to the motherboard?
Also, what is the yellow tape for? Isn't it enough to just epoxy the new battery or does the tape serve some purpose, like maybe electrical insulation?
if the battery is not for sale, where do you get it?
