Ga door naar hoofdinhoud
Dragon Touch A1x Plus Cameras Replacement
Wat je nodig hebt
  1. Dragon Touch A1x Plus Cameras Replacement, Battery: stap 1, afbeelding 1 van 1
    • Insert the plastic opening tool between the white back cover and black front over.
  2. Dragon Touch A1x Plus Cameras Replacement: stap 2, afbeelding 1 van 2 Dragon Touch A1x Plus Cameras Replacement: stap 2, afbeelding 2 van 2
    • Slide the plastic opening tool along the edgeof the device until back cover is detached and remove the cover.
    • You may need to pry the back cover off using the opening tool while moving it along the edge.
  3. Dragon Touch A1x Plus Cameras Replacement: stap 3, afbeelding 1 van 1
    • Remove the yellow tape holding the battery to the device using your fingers or plastic opening tool if necessary.
  4. Dragon Touch A1x Plus Cameras Replacement: stap 4, afbeelding 1 van 1
    • Use the hair dryer to melt the glue holding the battery to the device.
    • Be careful not to overheat the battery as it could cause the battery to combust.
  5. Dragon Touch A1x Plus Cameras Replacement: stap 5, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Plastic Cards
    $2.99
    Koop
    • Insert the plastic card under the battery and use it to remove the battery from the device.
    • Be careful not to deform the battery.
  6. Dragon Touch A1x Plus Cameras Replacement: stap 6, afbeelding 1 van 2 Dragon Touch A1x Plus Cameras Replacement: stap 6, afbeelding 2 van 2
    • Desolder the red and black wires connecting the battery to the motherboard and remove the battery.
  7. Dragon Touch A1x Plus Cameras Replacement, Cameras: stap 7, afbeelding 1 van 2 Dragon Touch A1x Plus Cameras Replacement, Cameras: stap 7, afbeelding 2 van 2
    • Remove black tape holding the cameras to the motherboard.
  8. Dragon Touch A1x Plus Cameras Replacement: stap 8, afbeelding 1 van 2 Dragon Touch A1x Plus Cameras Replacement: stap 8, afbeelding 2 van 2
    • Use your fingernail to flip up the small locking flap on the ZIF connector.
    • Pull the ribbon cable from the ZIF connector.
  9. Dragon Touch A1x Plus Cameras Replacement: stap 9, afbeelding 1 van 1
    • Remove the front camera from the device using your fingers.
  10. Dragon Touch A1x Plus Cameras Replacement: stap 10, afbeelding 1 van 2 Dragon Touch A1x Plus Cameras Replacement: stap 10, afbeelding 2 van 2
    • Melt the glue holding the rear camera in place using a hair dryer.
    • Insert the metal spludger under the rear camera and pry it free from the device.
Conclusie
Josh Null
313 Reputatie
3 handleidingen geschreven
IUPUI, Team S5-G5, Baechle Spring 2018 Lid van IUPUI, Team S5-G5, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G5
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 163
