Inleiding
This guide will walk you through how to replace the battery of the device. In order to do this you must first remove the back cover. Once the back cover is off, you can remove and replace the battery.
Wat je nodig hebt
Insert the plastic opening tool between the white back cover and black front over.
Gereedschap gebruikt in deze stap:Plastic Cards$2.99
Insert the plastic card under the battery and use it to remove the battery from the device.
Bijna klaar!
Conclusie
