Wat je nodig hebt
Remove the green board with the controls first.
DON'T USE FORCE, it should get lose easily. Don't bend the cables too much.
Remove the cable from the control board
Lift the display off, don't bed the cable too much.
Open the connector of the cable carefully. Don't scratch the board and don't use too much force. Ideally, use a plastic spudger of the ifixit-kit
The display got removed, not just fit the new display in reveresed order.
Follow the steps in reverse order to reassemble.
3 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Doe je mee?
Begin met vertalen ›
4Gids Commentaar
Great summary - clear and easy to follow. Display replaced in less than 30 minutes. Thanks.
Hi Tony,
I'm looking for a replacement screen for a Lumix DMC-TZ70 (there are none available from the link provided in the repair instructions), and wondered where you got yours?
Unfortunately, the display is no longer available from the linked site.
That depends a lot on your location. Mine was from Germany, but if you want to buy from e.g. the UK, you can type the model number and "screen" or "display" on a popular marketplace like ebay: https://www.ebay.co.uk/sch/i.html?_nkw=L...
I'll try to remove the link from the description, so there is no confusion.
