Ga door naar hoofdinhoud
Disassembly Guide
Wat je nodig hebt
  1. Disassembly Guide, Battery: stap 1, afbeelding 1 van 3 Disassembly Guide, Battery: stap 1, afbeelding 2 van 3 Disassembly Guide, Battery: stap 1, afbeelding 3 van 3
    • Locate the battery housing cover on the bottom of your camera.
    • Place a finger on the textured portion of the battery housing cover.
    • Slide the cover in the direction that the arrow is pointing.
    Vraag FixBot
    Voeg opmerking toe
  2. Disassembly Guide: stap 2, afbeelding 1 van 2 Disassembly Guide: stap 2, afbeelding 2 van 2
    • Use your finger to pivot the orange tab away from the battery.
    Vraag FixBot
    Voeg opmerking toe
  3. Disassembly Guide: stap 3, afbeelding 1 van 1
    • Pull the battery out of the housing with your fingers.
    Vraag FixBot
    Voeg opmerking toe
  4. Disassembly Guide, Motherboard: stap 4, afbeelding 1 van 2 Disassembly Guide, Motherboard: stap 4, afbeelding 2 van 2
    • Remove the two 4mm Hex screws that connect the grip to the camera with a Hex head screwdriver.
    • Remove the two Phillips screws to the left of the hex screws with a Phillips head screwdriver:
    • One 2mm screw
    • One 3mm screw
    • Remove the grip from the front of the camera by pulling it away from the lens and then away from the camera.
    Vraag FixBot
    Voeg opmerking toe
  5. Disassembly Guide: stap 5, afbeelding 1 van 1
    • Remove the following three Philips screws from the flash release side of the camera with a Philips Head screwdriver:
    • One 2.5mm screw
    • One 4.5mm screw
    • One 1.75mm screw
    Vraag FixBot
    Voeg opmerking toe
  6. Disassembly Guide: stap 6, afbeelding 1 van 1
    • Remove the following three Philips screws from the bottom of the camera with a Philips Head screwdriver:
    • One 3.25mm screw
    • One 2.5mm screw
    • One 2.75mm screw
    Vraag FixBot
    Voeg opmerking toe
  7. Disassembly Guide: stap 7, afbeelding 1 van 2 Disassembly Guide: stap 7, afbeelding 2 van 2
    • Rotate the LCD screen away from the camera.
    Vraag FixBot
    Voeg opmerking toe
  8. Disassembly Guide: stap 8, afbeelding 1 van 1
    • Remove the following four Phillips screws securing the back panel with a Philips Head screwdriver:
    • Two 3 mm screws
    • One 2mm screw
    • One 2.5 mm screw
    Vraag FixBot
    Voeg opmerking toe
  9. Disassembly Guide: stap 9, afbeelding 1 van 1
    • Lift the back casing up far enough to expose the ribbon cables.
    Vraag FixBot
    Voeg opmerking toe
  10. Disassembly Guide: stap 10, afbeelding 1 van 2 Disassembly Guide: stap 10, afbeelding 2 van 2
    • Use a plastic spudger to gently release the locking tab holding the ribbon cable, closest to the edge of the camera, in place.
    • Repeat this process for the second ribbon cable to the right.
    • Carefully lift the back casing away from the camera.
    Vraag FixBot
    Voeg opmerking toe
  11. Disassembly Guide: stap 11, afbeelding 1 van 1
    Vraag FixBot
    Voeg opmerking toe
  12. Disassembly Guide: stap 12, afbeelding 1 van 2 Disassembly Guide: stap 12, afbeelding 2 van 2
    • Remove the five Phillips screws that are attached to the copper plate with a Philips Head screwdriver:
    • Two 3mm screws
    • Two 1.5mm screws
    • One 4mm screw
    • Lift the copper plate away from the camera.
    Vraag FixBot
    Voeg opmerking toe
  13. Disassembly Guide: stap 13, afbeelding 1 van 3 Disassembly Guide: stap 13, afbeelding 2 van 3 Disassembly Guide: stap 13, afbeelding 3 van 3
    • Remove the following three Phillips screws securing the silver plate with a Philips Head screwdriver:
    • Two 2.9mm screws on the front of the camera
    • One 1.8mm screw on the bottom of the camera
    • Lift the silver plate away from the camera.
    Vraag FixBot
    Voeg opmerking toe
  14. Disassembly Guide: stap 14, afbeelding 1 van 2 Disassembly Guide: stap 14, afbeelding 2 van 2
    • Use the plastic spudger to lift up both sides of the ribbon cable from its connector pins.
    • The male end is on the left and the female end is on the right. The right side of the cable is notched.
    Vraag FixBot
    Voeg opmerking toe
  15. Disassembly Guide: stap 15, afbeelding 1 van 3 Disassembly Guide: stap 15, afbeelding 2 van 3 Disassembly Guide: stap 15, afbeelding 3 van 3
    • Use the flat end of the plastic spudger to rotate the black plastic locking tab towards the ribbon cable.
    • Insert the pointed end of the plastic spudger into a small hole on the side of the ribbon cable and pull the ribbon cable out of its housing.
    • Use the flat end of the plastic spudger to pry the ribbon cable connector from the motherboard.
    • Both ribbon cables should be removed after this step.
    Vraag FixBot
    Voeg opmerking toe
  16. Disassembly Guide: stap 16, afbeelding 1 van 2 Disassembly Guide: stap 16, afbeelding 2 van 2
    • Release the flash by sliding the flash release towards the lens.
    • The flash release is located on the side of the camera closest to the lens.
    Vraag FixBot
    Voeg opmerking toe
  17. Disassembly Guide: stap 17, afbeelding 1 van 2 Disassembly Guide: stap 17, afbeelding 2 van 2
    • Remove the following two Phillips screws from the flash cavity with a Philips Head screwdriver:
    • Remove the 2mm screw to the right of the flash.
    • Remove the 2.5mm screw to the left of the flash.
    Vraag FixBot
    Voeg opmerking toe
  18. Disassembly Guide: stap 18, afbeelding 1 van 2 Disassembly Guide: stap 18, afbeelding 2 van 2
    • Remove the 2.5mm Phillips screw from the front plate with a Phillips head screwdriver.
    • Pull up on the top portion of the camera to separate the top casing from the camera body.
    • Make sure the flash is up. Otherwise the top casing will not release.
    Vraag FixBot
    Voeg opmerking toe
  19. Disassembly Guide: stap 19, afbeelding 1 van 2 Disassembly Guide: stap 19, afbeelding 2 van 2
    • Remove the 3.5mm Phillips screw from the grey tab on the top of the camera with a Philips Head screwdriver.
    • Rotate the camera so the back panel is facing you.
    • Remove the 1.4mm Phillips screw from the sliver tab near the top of the camera with a Philips Head screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  20. Disassembly Guide: stap 20, afbeelding 1 van 2 Disassembly Guide: stap 20, afbeelding 2 van 2
    • Use the flat end of the plastic spudger to release the plastic retaining clip on the side plate closest to the lens.
    • Rotate the side plate closest to the lens toward the lens of the camera and then pull the plate away from the camera.
    Vraag FixBot
    Voeg opmerking toe
  21. Disassembly Guide: stap 21, afbeelding 1 van 3 Disassembly Guide: stap 21, afbeelding 2 van 3 Disassembly Guide: stap 21, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Release the plastic locking tab of the upper ribbon cable with the plastic spudger.
    • Pull the top ribbon cable from its mount with the fine tip metal tweezers.
    • Remove the bottom ribbon cable with the fine tip metal tweezers by pulling it toward the flash switch side of the camera.
    • The bottom ribbon cable does not have a locking tab; it simply slides in and out.
    Vraag FixBot
    Voeg opmerking toe
  22. Disassembly Guide: stap 22, afbeelding 1 van 1
    • Pull the front plate off the camera body.
    • It should slide off easily. If it does not, ensure that all screws and ribbon cables from previous steps have been removed or disconnected.
    Vraag FixBot
    Voeg opmerking toe
  23. Disassembly Guide: stap 23, afbeelding 1 van 1
    • Remove the rubber dust cover from the camera by moving the hooks away from the three prongs holding them in place and then pulling the cover away from the camera.
    Vraag FixBot
    Voeg opmerking toe
  24. Disassembly Guide: stap 24, afbeelding 1 van 2 Disassembly Guide: stap 24, afbeelding 2 van 2
    • Remove the following two Phillips screws from the side of the camera with the three connector ports with a Phillips head screwdriver:
    • One 2.5mm screw
    • One 3.3mm screw
    • Pull the metal shield away from the camera.
    Vraag FixBot
    Voeg opmerking toe
  25. Disassembly Guide: stap 25, afbeelding 1 van 3 Disassembly Guide: stap 25, afbeelding 2 van 3 Disassembly Guide: stap 25, afbeelding 3 van 3
    • Use the plastic spudger to remove the ribbon cable from the motherboard by placing the spudger under the ribbon cable connector and pulling up.
    • Remove the 2.8mm screw from the motherboard.
    • Do not try to remove the motherboard from the camera yet.
    • Carefully rotate the motherboard upward.
    • Use the plastic spudger to remove the ribbon cable from the bottom of the motherboard by placing the spudger under the ribbon cable connector and pulling up.
    Vraag FixBot
    Voeg opmerking toe
  26. Disassembly Guide: stap 26, afbeelding 1 van 1
    • Lift the motherboard away from the camera.
    Vraag FixBot
    Voeg opmerking toe
  27. Disassembly Guide, Lens: stap 27, afbeelding 1 van 3 Disassembly Guide, Lens: stap 27, afbeelding 2 van 3 Disassembly Guide, Lens: stap 27, afbeelding 3 van 3
    • Lay the camera on a flat surface while performing these steps because removing the frame causes the camera to fall apart.
    • Remove the four 4.25mm Philips screws from the silver frame that surrounds the lens of the camera with a Philips Head screwdriver.
    • Remove the frame by lifting straight up.
    Vraag FixBot
    Voeg opmerking toe
  28. Disassembly Guide: stap 28, afbeelding 1 van 1
    • Separate the lens from the other components of the camera.
    Vraag FixBot
    Voeg opmerking toe
  29. Disassembly Guide, Disassembly Guide: stap 29, afbeelding 1 van 1
    • You have disassembled the Canon PowerShot G1 X Mark II!
    Vraag FixBot
    Voeg opmerking toe
Conclusie
7 andere personen hebben deze handleiding voltooid.
Ryan Dunn
578 Reputatie
3 handleidingen geschreven
Cal Poly, Team 70-2, Forte Winter 2016 Lid van Cal Poly, Team 70-2, Forte Winter 2016
CPSU-FORTE-W16S70G2
4 Leden
4 handleidingen geschreven
5Gids Commentaar
Surely these are JIS screws not Phillips. A Phillips screwdriver will chew the heads up.
maico61 - Antwoord Deel
I have an LCD display problem and would like to disassemble it, the guide does not cover anything to do with the LDC assembly, otherwise a very good guide. I’ll attempt it anyway once I feel like a risk.
Alan Cattalon - Antwoord Deel
Fabuloso. La pantalla de mi camara canon gx1 cuando la invertias se apagaba. Lo que he hecho fue comprar un cable ribbon nuevo en aliexpress y substituirlo. Asunto arreglado por 7euros.
En este tutorial, falta como desmontar la pantalla. Para hacerlo debes retirar los tornillos de la pantalla con delicadeza, despegar el cable con delicadeza y montar la pantalla otra vez.
MIGUEL A. MARTINEZ GOMEZ - Antwoord Deel
hola miguel angel, cual es ese cable? podrias enlazarlo, mi pantalla da fallos y debe ser ese ribbon. gracias!
alvarezrodriguezrc - Antwoord Deel
Thanks for this great guide ! I need to disassemble and clean the external flash connector in the top portion of the camera because of some dirt and even corrosion - I found no way how to do this, I removed all screws but I was not able to remove the metallic structure. Any idea to take this apart ? thanks in advance...
M Df - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 30
Afgelopen 30 dagen: 112
Altijd: 11,828
