Ga door naar hoofdinhoud
Disassembling the Linksys E1200
Wat je nodig hebt
    1. Disassembling the Linksys E1200, Cover and Circuit Board: stap 1, afbeelding 1 van 3 Disassembling the Linksys E1200, Cover and Circuit Board: stap 1, afbeelding 2 van 3 Disassembling the Linksys E1200, Cover and Circuit Board: stap 1, afbeelding 3 van 3
      • Opening the device will void your warranty.
      • Anti-slip pads cover three screws that hold the device together. Pry off the pads to access the screws.
      • Remove the three screws.
      • Save the pads for reassembly.
      Vraag FixBot
      Voeg opmerking toe
    2. Disassembling the Linksys E1200: stap 2, afbeelding 1 van 3 Disassembling the Linksys E1200: stap 2, afbeelding 2 van 3 Disassembling the Linksys E1200: stap 2, afbeelding 3 van 3
      • Once the three screws are removed, the device is ready for disassembly.
      • Push up on the rear flap while holding down on the rest of the body. This will open a small gap.
      • Insert the plastic opening tool in the gap and begin prying on the corner.
      • Continue to pry around the body of the case. Separate both sides of the case with this method.
      Vraag FixBot
      Voeg opmerking toe
    3. Disassembling the Linksys E1200: stap 3, afbeelding 1 van 2 Disassembling the Linksys E1200: stap 3, afbeelding 2 van 2
      • Once the sides are released, the front of the cover can be removed.
      • Use a plastic opening tool to separate the front of the cover from the body.
      • It is helpful to use a different plastic opening tool as a wedge on the sides to prevent them from snapping back together.
      Vraag FixBot
      Voeg opmerking toe
    4. Disassembling the Linksys E1200: stap 4, afbeelding 1 van 3 Disassembling the Linksys E1200: stap 4, afbeelding 2 van 3 Disassembling the Linksys E1200: stap 4, afbeelding 3 van 3
      • The cover can now be removed.
      • To repair anything on the circuit board, use the plastic opening tool to pull back on the two tabs holding it down.
      • Use caution when pulling on the tabs as they are stiff and easy to break.
      • Keep the tabs if they snap off. The tabs can be reattached with glue when reassembling the device.
      Vraag FixBot
      Voeg opmerking toe
    5. Disassembling the Linksys E1200: stap 5, afbeelding 1 van 3 Disassembling the Linksys E1200: stap 5, afbeelding 2 van 3 Disassembling the Linksys E1200: stap 5, afbeelding 3 van 3
      • If the antenna needs to be disconnected, desolder the connection and reattach it prior to reassembly.
      • If the ethernet ports, power port, or reset button are damaged, the large solder points allow you to replace them.
      • Many components on the board cannot be serviced. These components were attached by a machine and cannot be removed.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
13 andere personen hebben deze handleiding voltooid.
Tahisha Hicks
409 Reputatie
4 handleidingen geschreven
Michigan Tech, Team 5-4, Lauer Spring 2014 Lid van Michigan Tech, Team 5-4, Lauer Spring 2014
MTU-LAUER-S14S5G4
3 Leden
23 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 47
Altijd: 7,765
