Ga door naar hoofdinhoud
Disassembling VTech MobiGo Touch Learning System Keyboard
Wat je nodig hebt
    1. Disassembling VTech MobiGo Touch Learning System Keyboard, Case: stap 1, afbeelding 1 van 1
      • Remove the battery covers and the four batteries.
      Vraag FixBot
      Voeg opmerking toe
    2. Disassembling VTech MobiGo Touch Learning System Keyboard: stap 2, afbeelding 1 van 2 Disassembling VTech MobiGo Touch Learning System Keyboard: stap 2, afbeelding 2 van 2
      • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
      • Remove the eight 6.0 mm JIS #0 case screws.
      Vraag FixBot
      Voeg opmerking toe
    3. Disassembling VTech MobiGo Touch Learning System Keyboard: stap 3, afbeelding 1 van 2 Disassembling VTech MobiGo Touch Learning System Keyboard: stap 3, afbeelding 2 van 2
      • Using a plastic opening tool, separate the two pieces of the case carefully.
      Vraag FixBot
      Voeg opmerking toe
    1. Disassembling VTech MobiGo Touch Learning System Keyboard, Disassembling VTech MobiGo Touch Learning System Keyboard: stap 4, afbeelding 1 van 2 Disassembling VTech MobiGo Touch Learning System Keyboard, Disassembling VTech MobiGo Touch Learning System Keyboard: stap 4, afbeelding 2 van 2
      • Remove the six 6.5 mm Philips J0 screws that are connected to the circuit board.
      • Use light pressure to prevent damage to the circuit board.
      Vraag FixBot
      Voeg opmerking toe
    2. Disassembling VTech MobiGo Touch Learning System Keyboard: stap 5, afbeelding 1 van 1
      • Remove the 9.0 mm Philips J0 screw from the blue plastic cover.
      • Once the screw is removed, remove the blue plastic cover.
      Vraag FixBot
      Voeg opmerking toe
    3. Disassembling VTech MobiGo Touch Learning System Keyboard: stap 6, afbeelding 1 van 2 Disassembling VTech MobiGo Touch Learning System Keyboard: stap 6, afbeelding 2 van 2
      • Remove the two 4.0 mm Philips J0 screws located on the orange case.
      • Use gentle force to prevent stripping of screws.
      Vraag FixBot
      Voeg opmerking toe
    4. Disassembling VTech MobiGo Touch Learning System Keyboard: stap 7, afbeelding 1 van 3 Disassembling VTech MobiGo Touch Learning System Keyboard: stap 7, afbeelding 2 van 3 Disassembling VTech MobiGo Touch Learning System Keyboard: stap 7, afbeelding 3 van 3
      • Remove the two "L" shaped brackets located on both sides of the device.
      • Use the magnetic mat to store these brackets.
      Vraag FixBot
      Voeg opmerking toe
    5. Disassembling VTech MobiGo Touch Learning System Keyboard: stap 8, afbeelding 1 van 1
      • Locate the spring that was connected to the "L" shaped bracket and slowly remove it.
      Vraag FixBot
      Voeg opmerking toe
    6. Disassembling VTech MobiGo Touch Learning System Keyboard: stap 9, afbeelding 1 van 2 Disassembling VTech MobiGo Touch Learning System Keyboard: stap 9, afbeelding 2 van 2
      • Gently lift the circuit board from the case using a plastic opening tool.
      • Make sure to use a plastic opening tool for this step.
      Vraag FixBot
      Voeg opmerking toe
    7. Disassembling VTech MobiGo Touch Learning System Keyboard: stap 10, afbeelding 1 van 1
      • Remove the 3.5 mm Philips J0 screw located underneath the circuit board.
      • Keep the circuit board out of the way to avoid damaging it.
      Vraag FixBot
      Voeg opmerking toe
    8. Disassembling VTech MobiGo Touch Learning System Keyboard: stap 11, afbeelding 1 van 1
      • Slowly remove the keyboard panel.
      • Use a spudger if necessary.
      • The keys will fall out once the keyboard panel is removed.
      • Remove all of the keys and set them aside with the keyboard panel.
      Vraag FixBot
      Voeg opmerking toe
    9. Disassembling VTech MobiGo Touch Learning System Keyboard: stap 12, afbeelding 1 van 1
      • Gently remove the keyboard circuit board with a plastic opening tool.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
RBansil
221 Reputatie
2 handleidingen geschreven
USF Tampa, Team 8-3, Eyestone Fall 2015 Lid van USF Tampa, Team 8-3, Eyestone Fall 2015
USFT-EYESTONE-F15S8G3
3 Leden
49 handleidingen geschreven
1Gids Commentaar
Was gifted a mobigo2 for my niece but it came without keyboard .. I was curious if you knew where I might find a replacement keyboard?
ROXXY - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 34
Altijd: 2,468
