Ga door naar hoofdinhoud
Disassembling Sony Reader Touch Edition PRS-600 Inner Casing
Wat je nodig hebt
    1. Disassembling Sony Reader Touch Edition PRS-600 Inner Casing, Back Panel: stap 1, afbeelding 1 van 1
      • Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
      Vraag FixBot
      Voeg opmerking toe
    2. Disassembling Sony Reader Touch Edition PRS-600 Inner Casing: stap 2, afbeelding 1 van 1
      • Slide the back cover off by pushing it to the left, away from the side that held the screws.
      • Remove the cover.
      Vraag FixBot
      Voeg opmerking toe
    3. Disassembling Sony Reader Touch Edition PRS-600 Inner Casing: stap 3, afbeelding 1 van 1
      • This is what the device should look like once the back cover panel has been removed.
      Vraag FixBot
      Voeg opmerking toe
    1. Disassembling Sony Reader Touch Edition PRS-600 Inner Casing, Battery: stap 4, afbeelding 1 van 1
      • Once the back cover has been removed locate the battery in the bottom right corner of the device.
      • Using the pointed end of the spudger, push out the white plug that is connected to the battery from its beige base.
      Vraag FixBot
      Voeg opmerking toe
    2. Disassembling Sony Reader Touch Edition PRS-600 Inner Casing: stap 5, afbeelding 1 van 1
      • Use the flat end of the spudger to pry the battery out of its holder. There may be glue holding it in place.
      Vraag FixBot
      Voeg opmerking toe
    1. Disassembling Sony Reader Touch Edition PRS-600 Inner Casing, Inner Casing: stap 6, afbeelding 1 van 1
      • Using a screwdriver remove the four 1.4 mm screws that are holding the black plastic casing in place.
      Vraag FixBot
      Voeg opmerking toe
    2. Disassembling Sony Reader Touch Edition PRS-600 Inner Casing: stap 7, afbeelding 1 van 1
      • Pry open the black casing to access the screw that is holding down the battery holder.
      • Remove the one 1.4 mm screw that is holding down the battery holder located under black casing.
      • Lift the black inner casing and the battery holder out of the device.
      • The battery holder and the black inner casing are connected by a thin strip of copper. There may be glue holding the black inner casing in place.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Terrika Ngobili
873 Reputatie
7 handleidingen geschreven
Clemson, Team 1-4, Benson Fall 2014 Lid van Clemson, Team 1-4, Benson Fall 2014
CLEM-BENSON-F14S1G4
4 Leden
77 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 35
Altijd: 1,246
