Ga door naar hoofdinhoud
Disassembling Samsung Galaxy S Blaze Whole Device
Wat je nodig hebt
  1. Disassembling Samsung Galaxy S Blaze Whole Device, Device: stap 1, afbeelding 1 van 1
    • Remove the back plate.
  2. Disassembling Samsung Galaxy S Blaze Whole Device: stap 2, afbeelding 1 van 1
    • Remove the battery from the device.
  3. Disassembling Samsung Galaxy S Blaze Whole Device: stap 3, afbeelding 1 van 2 Disassembling Samsung Galaxy S Blaze Whole Device: stap 3, afbeelding 2 van 2
    • Use a Phillips head screwdriver size 00.
    • Remove the 4mm screws from the frame.
    • The eight screws are all the same size.
  4. Disassembling Samsung Galaxy S Blaze Whole Device: stap 4, afbeelding 1 van 1
    • Remove the frame from the phone by using the blue plastic opening tool.
    • Work around the phone with the tool until the frame is off.
    • You may need to use a bit of force to pry off the frame.
  5. Disassembling Samsung Galaxy S Blaze Whole Device: stap 5, afbeelding 1 van 1
    • The volume rocker is attached to the frame by two plastic prongs.
    • Unhook the prongs from the frame and remove the volume rocker.
  6. Disassembling Samsung Galaxy S Blaze Whole Device: stap 6, afbeelding 1 van 1
    • The SD card slot is held in place by a small tab.
    • Unhook the tab of the SD card slot, from the frame of the phone.
  7. Disassembling Samsung Galaxy S Blaze Whole Device: stap 7, afbeelding 1 van 1
    • The power button is attached to the phone with two prongs.
    • Unhook the prongs of the power button from the frame of the phone.
  8. Disassembling Samsung Galaxy S Blaze Whole Device: stap 8, afbeelding 1 van 3 Disassembling Samsung Galaxy S Blaze Whole Device: stap 8, afbeelding 2 van 3 Disassembling Samsung Galaxy S Blaze Whole Device: stap 8, afbeelding 3 van 3
    • 4 ribbon cable connectors hold the motherboard to the phone.
    • The first 3 are all on one side.
    • Use the blue plastic opening tool to unlatch the wire ribbons from the motherboard.
  9. Disassembling Samsung Galaxy S Blaze Whole Device: stap 9, afbeelding 1 van 1
    • Flip the motherboard over to access the last ribbon cable connector.
    • Unlatch the final ribbon cable connector from the phone.
    • Remove the motherboard from the phone.
  10. Disassembling Samsung Galaxy S Blaze Whole Device: stap 10, afbeelding 1 van 1
    • All of the parts are seen here.
Conclusie
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
Jake Best
261 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 20
Altijd: 821
