Ga door naar hoofdinhoud
Disassembling REL T5 Main Amplifier
Wat je nodig hebt
    1. Disassembling REL T5 Main Amplifier, Remove screws: stap 1, afbeelding 1 van 3 Disassembling REL T5 Main Amplifier, Remove screws: stap 1, afbeelding 2 van 3 Disassembling REL T5 Main Amplifier, Remove screws: stap 1, afbeelding 3 van 3
      • Place the subwoofer on it legs to protect the driver. Be careful not to touch the driver/speaker on the bottom when you handle the case.
      • Using the 3mm hex tool, remove only the outer rim of screws, starting from the bottom.
      • Make sure to support the plate amp by gripping the heat sink.
      • Remove the top screws. Be aware: the heavy transformer is located at the top. Removing the top screws will probably make the plate amp tilt out of the case.
      • Using the heatsink, carefully lift the plate amp out of the case. Again: it's heavier than you might expect!
      Vraag FixBot
      Voeg opmerking toe
    2. Disassembling REL T5 Main Amplifier, Disconnect the driver: stap 2, afbeelding 1 van 2 Disassembling REL T5 Main Amplifier, Disconnect the driver: stap 2, afbeelding 2 van 2
      • The plate amp is still connected to the driver via faston connectors. I found it easiest to disconnect the driver connectors, but removing them from the amplifier side works equally well.
      Vraag FixBot
      Voeg opmerking toe
    3. Disassembling REL T5 Main Amplifier, Remove plate amp: stap 3, afbeelding 1 van 1
      • You've now removed the plate amp. Set it aside on the heatsink side. The height of the heatsink will make sure that the controls are not damaged.
      • Now is a good time to check the voltage rails for residual voltage. Everything after the rectifier bridge should be <45V, but always take appropriate precautions when it comes to mains powered devices.
      Vraag FixBot
      Voeg opmerking toe
    1. Disassembling REL T5 Main Amplifier, Snip all connecting trywraps: stap 4, afbeelding 1 van 2 Disassembling REL T5 Main Amplifier, Snip all connecting trywraps: stap 4, afbeelding 2 van 2
      • Snip all tywraps, such that all cables can be manipulated freely.
      Vraag FixBot
      Voeg opmerking toe
    2. Disassembling REL T5 Main Amplifier, Disconnect connectors: stap 5, afbeelding 1 van 2 Disassembling REL T5 Main Amplifier, Disconnect connectors: stap 5, afbeelding 2 van 2
      • Disconnect all connectors that tie to the transformer
      • Make sure that all leads can be manipulated freely.
      Vraag FixBot
      Voeg opmerking toe
    3. Disassembling REL T5 Main Amplifier, Loosen screws: stap 6, afbeelding 1 van 2 Disassembling REL T5 Main Amplifier, Loosen screws: stap 6, afbeelding 2 van 2
      • Start loosening the screws on the back using the m3 hex tool
      • Don't remove them fully, yet though.
      Vraag FixBot
      Voeg opmerking toe
    4. Disassembling REL T5 Main Amplifier, Remove screws: stap 7, afbeelding 1 van 2 Disassembling REL T5 Main Amplifier, Remove screws: stap 7, afbeelding 2 van 2
      • Turn the amp on it's back.
      • Remove the nuts from the screws that where loosened on the back.
      • Remove the philips screws using a #2.
      Vraag FixBot
      Voeg opmerking toe
    5. Disassembling REL T5 Main Amplifier, Loosen dampening rubber: stap 8, afbeelding 1 van 1
      • Loosen the dampening rubber by running a Halberd Spudger underneath it.
      • The rubber is not adhered to the aluminium and is pretty tough, so a moderate amount of force is allowed.
      Vraag FixBot
      Voeg opmerking toe
    6. Disassembling REL T5 Main Amplifier, Remove transformer: stap 9, afbeelding 1 van 2 Disassembling REL T5 Main Amplifier, Remove transformer: stap 9, afbeelding 2 van 2
      • You can now remove the transformer from the plate. Be careful not to damage the controls on the plate now that the assembly is a lot lighter.
      Vraag FixBot
      Voeg opmerking toe
    1. Disassembling REL T5 Main Amplifier, Remove connectors: stap 10, afbeelding 1 van 2 Disassembling REL T5 Main Amplifier, Remove connectors: stap 10, afbeelding 2 van 2
      • Remove the connectors to the amp board.
      Vraag FixBot
      Voeg opmerking toe
    2. Disassembling REL T5 Main Amplifier: stap 11, afbeelding 1 van 2 Disassembling REL T5 Main Amplifier: stap 11, afbeelding 2 van 2
      • Discharge the capacitor e.g. using a replacement 1k3 power resistor.
      • Carefully bridge the resistor across the + and - legs of the recifier, but don't touch anything else.
      Vraag FixBot
      Voeg opmerking toe
      • Verify that the voltage is near zero. 0.2V or so is fine.
      • The voltage starts at around 100V, so be careful.
      Vraag FixBot
      Voeg opmerking toe
    3. Disassembling REL T5 Main Amplifier, Remove component screws: stap 13, afbeelding 1 van 2 Disassembling REL T5 Main Amplifier, Remove component screws: stap 13, afbeelding 2 van 2
      • Remove the screws to the thermistor.
      • Remove the screws to the transistors.
      • Store them in a separate baggy.
      Vraag FixBot
      Voeg opmerking toe
    4. Disassembling REL T5 Main Amplifier, Remove PCB screws: stap 14, afbeelding 1 van 3 Disassembling REL T5 Main Amplifier, Remove PCB screws: stap 14, afbeelding 2 van 3 Disassembling REL T5 Main Amplifier, Remove PCB screws: stap 14, afbeelding 3 van 3
      • Remove screws for four corners.
      • Store them in or on their posts.
      Vraag FixBot
      Voeg opmerking toe
    5. Disassembling REL T5 Main Amplifier, Lift the PCB: stap 15, afbeelding 1 van 1
      • Gently lift up the PCB. The transistors might be held down by thermal paste, so use a spudger to release them.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Jasper van Zuijlen
1.044 Reputatie
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 50
Altijd: 85
