Ga door naar hoofdinhoud
Disassembling Power Mac G4 M5183 DVD-ROM Drive
Wat je nodig hebt
    1. Disassembling Power Mac G4 M5183 DVD-ROM Drive, Opening PowerMac G4 M5183 Case: stap 1, afbeelding 1 van 2 Disassembling Power Mac G4 M5183 DVD-ROM Drive, Opening PowerMac G4 M5183 Case: stap 1, afbeelding 2 van 2
      • Pull on outer latch.
      • Lower door until it is level with your work surface.
      • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
      Vraag FixBot
      Voeg opmerking toe
    1. Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: stap 2, afbeelding 1 van 2 Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: stap 2, afbeelding 2 van 2
      • Removing the faceplate.
      • On the inside of the case, find the two plastic tabs.
      • While depressing the tabs, remove the faceplate by pulling and rotating outward.
      Vraag FixBot
      Voeg opmerking toe
    2. Disassembling Power Mac G4 M5183 DVD-ROM Drive: stap 3, afbeelding 1 van 1
      • Remove the two screws on the front of the drive with the Phillips #1 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. Disassembling Power Mac G4 M5183 DVD-ROM Drive: stap 4, afbeelding 1 van 3 Disassembling Power Mac G4 M5183 DVD-ROM Drive: stap 4, afbeelding 2 van 3 Disassembling Power Mac G4 M5183 DVD-ROM Drive: stap 4, afbeelding 3 van 3
      • Pull the drive out to allow access to the power and ribbon cables. Do not fully remove.
      • Remove both the power and ribbon cable.
      Vraag FixBot
      Voeg opmerking toe
    1. Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: stap 5, afbeelding 1 van 3 Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: stap 5, afbeelding 2 van 3 Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: stap 5, afbeelding 3 van 3
      • Remove DVD drive from the drive bay.
      • Lift the two metal tabs on the back of the shielding and remove.
      • Remove the four screws on the bottom of the drive with the Phillips #1 screwdriver.
      • Slide out DVD drive.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
12 andere personen hebben deze handleiding voltooid.
Stephen Scruggs
2.283 Reputatie
2 handleidingen geschreven
Cal Poly, Team 13-24, Maness Winter 2010 Lid van Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Leden
55 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 61
Altijd: 12,293
