Ga door naar hoofdinhoud
Disassembling Olympus Stylus 725 SW Battery
  1. Disassembling Olympus Stylus 725 SW Battery, Disassembling Olympus Stylus 725 SW Battery: stap 1, afbeelding 1 van 2 Disassembling Olympus Stylus 725 SW Battery, Disassembling Olympus Stylus 725 SW Battery: stap 1, afbeelding 2 van 2
    • The battery is located on the bottom of the camera.
    • Remove the battery by placing your thumb on the bottom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
    • If the battery is dead, charge it for 60-90 minutes.
    • When installing a charged battery, align the battery appropriately. The positive signs and negative should line up.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Follow these instructions in reverse order to reassemble your device.
Bobby Hodges
49 Reputatie
6 handleidingen geschreven
Cal Poly, Team 33-71, Johann Spring 2010 Lid van Cal Poly, Team 33-71, Johann Spring 2010
CPSU-JOHANN-S10S33G71
4 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 72
Altijd: 4,083
