Ga door naar hoofdinhoud
Disassembling Nokia E61i Volume Control Buttons
Wat je nodig hebt
    1. Disassembling Nokia E61i Volume Control Buttons, Battery: stap 1, afbeelding 1 van 2 Disassembling Nokia E61i Volume Control Buttons, Battery: stap 1, afbeelding 2 van 2
      • First, gather all necessary tools.
      • Remove the back cover to access the battery by pushing the tab on the bottom of the cover.
      • Slide the back cover downwards off of the phone while pressing down on the tab.
      Vraag FixBot
      Voeg opmerking toe
    2. Disassembling Nokia E61i Volume Control Buttons: stap 2, afbeelding 1 van 1
      • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
      Vraag FixBot
      Voeg opmerking toe
    3. Disassembling Nokia E61i Volume Control Buttons: stap 3, afbeelding 1 van 1
      • Lift the battery out using your finger.
      • The E61i uses a Nokia BP-4L standard battery.
      Vraag FixBot
      Voeg opmerking toe
    1. Disassembling Nokia E61i Volume Control Buttons, Front Cover: stap 4, afbeelding 1 van 2 Disassembling Nokia E61i Volume Control Buttons, Front Cover: stap 4, afbeelding 2 van 2
      • To remove the top of the back cover, pry the sides and pop it off.
      • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Disassembling Nokia E61i Volume Control Buttons: stap 5, afbeelding 1 van 1
      • Remove the cover by pulling it up and off.
      Vraag FixBot
      Voeg opmerking toe
    1. Disassembling Nokia E61i Volume Control Buttons, Display: stap 6, afbeelding 1 van 2 Disassembling Nokia E61i Volume Control Buttons, Display: stap 6, afbeelding 2 van 2
      • Take off the casing and keyboard.
      • Remove the screws while holding the screen in place using a Torx T6 screwdriver.
      • Remove the single screw while holding the screen in place using a Torx T5 screwdriver.
      • Lift the ribbon, disconnecting contact with the motherboard.
      • Firmly press the contacts into place to connect the ribbon and the motherboard when reassembling.
      Vraag FixBot
      Voeg opmerking toe
    2. Disassembling Nokia E61i Volume Control Buttons: stap 7, afbeelding 1 van 2 Disassembling Nokia E61i Volume Control Buttons: stap 7, afbeelding 2 van 2
      • Gently pull the screen off of the phone.
      • Be sure not to rip the sticker that connects the display and the motherboard.
      • Pull the silver case off to completely free the cracked or damaged screen.
      Vraag FixBot
      Voeg opmerking toe
    1. Disassembling Nokia E61i Volume Control Buttons, Motherboard: stap 8, afbeelding 1 van 3 Disassembling Nokia E61i Volume Control Buttons, Motherboard: stap 8, afbeelding 2 van 3 Disassembling Nokia E61i Volume Control Buttons, Motherboard: stap 8, afbeelding 3 van 3
      • Pull the green motherboard from the back casing.
      Vraag FixBot
      Voeg opmerking toe
    1. Disassembling Nokia E61i Volume Control Buttons, Volume Control Buttons: stap 9, afbeelding 1 van 1
      • The volume control buttons are secured to the frame only by their fit around a small piece of the plastic. Using a small flat-head screwdriver or other flat object, lift the ribbon over this piece of the cover.
      Vraag FixBot
      Voeg opmerking toe
    2. Disassembling Nokia E61i Volume Control Buttons: stap 10, afbeelding 1 van 1
      • Next, remove the volume control buttons from the cover by pushing or pulling them out away from the interior of the cover.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Christopher Patton
208 Reputatie
12 handleidingen geschreven
Cal Poly, Team 9-63, Walters Spring 2011 Lid van Cal Poly, Team 9-63, Walters Spring 2011
CPSU-WALTERS-S11S9G63
5 Leden
108 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 29
Altijd: 2,024
