Ga door naar hoofdinhoud
Disassembling Nokia 3395 Inner Components
Wat je nodig hebt
  1. Disassembling Nokia 3395 Inner Components, Back Case: stap 1, afbeelding 1 van 3 Disassembling Nokia 3395 Inner Components, Back Case: stap 1, afbeelding 2 van 3 Disassembling Nokia 3395 Inner Components, Back Case: stap 1, afbeelding 3 van 3
    • Turn the phone off.
    • Hold the phone, and gently press the white button located at the bottom of the phone.
    • While pressing the button, slide the back plate upwards, opening the plate.
    Vraag FixBot
    Voeg opmerking toe
  2. Disassembling Nokia 3395 Inner Components, Battery: stap 2, afbeelding 1 van 2 Disassembling Nokia 3395 Inner Components, Battery: stap 2, afbeelding 2 van 2
    • Locate grey buttons beneath battery (shown).
    • Spread buttons simultaneously away from each other and the battery will pop out.
    • Remove battery from phone.
    Vraag FixBot
    Voeg opmerking toe
  3. Disassembling Nokia 3395 Inner Components, Front Case: stap 3, afbeelding 1 van 2 Disassembling Nokia 3395 Inner Components, Front Case: stap 3, afbeelding 2 van 2
    • Push the two black buttons on the side with your thumbs forward. This will release the front faceplate.
    • Flip over the device, and pry the faceplate away.
    Vraag FixBot
    Voeg opmerking toe
  4. Disassembling Nokia 3395 Inner Components, Screen: stap 4, afbeelding 1 van 2 Disassembling Nokia 3395 Inner Components, Screen: stap 4, afbeelding 2 van 2
    • Remove six T6 screws.
    Vraag FixBot
    Voeg opmerking toe
  5. Disassembling Nokia 3395 Inner Components: stap 5, afbeelding 1 van 2 Disassembling Nokia 3395 Inner Components: stap 5, afbeelding 2 van 2
    • Insert spudger between screen assembly and phone body.
    • Spread apart as shown. Avoid damaging the screen assembly by removing the screen slowly.
    Vraag FixBot
    Voeg opmerking toe
  6. Disassembling Nokia 3395 Inner Components, Logic Board: stap 6, afbeelding 1 van 2 Disassembling Nokia 3395 Inner Components, Logic Board: stap 6, afbeelding 2 van 2
    • Remove logic board as shown.
    Vraag FixBot
    Voeg opmerking toe
  7. Disassembling Nokia 3395 Inner Components, Inner Components: stap 7, afbeelding 1 van 1
    • Use the following legend to locate each component:
    • Microphone/power assembly.
    • Vibrating unit.
    • SIM card reader.
    • Audio speaker.
    • Power toggle button.
    • Battery connector.
    Vraag FixBot
    Voeg opmerking toe
  8. Disassembling Nokia 3395 Inner Components: stap 8, afbeelding 1 van 2 Disassembling Nokia 3395 Inner Components: stap 8, afbeelding 2 van 2
    • Insert spudger between power assembly/micro-phone and phone body.
    • Pry as shown and remove the power assembly/microphone.
    Vraag FixBot
    Voeg opmerking toe
  9. Disassembling Nokia 3395 Inner Components: stap 9, afbeelding 1 van 1
    • Once located, the following components are easily removed by pulling them out with your hand.
    • Vibrating unit.
    • SIM card reader.
    • Audio speaker.
    Vraag FixBot
    Voeg opmerking toe
  10. Disassembling Nokia 3395 Inner Components: stap 10, afbeelding 1 van 2 Disassembling Nokia 3395 Inner Components: stap 10, afbeelding 2 van 2
    • Audio speaker.
    Vraag FixBot
    Voeg opmerking toe
  11. Disassembling Nokia 3395 Inner Components: stap 11, afbeelding 1 van 2 Disassembling Nokia 3395 Inner Components: stap 11, afbeelding 2 van 2
    • SIM card reader.
    Vraag FixBot
    Voeg opmerking toe
  12. Disassembling Nokia 3395 Inner Components: stap 12, afbeelding 1 van 2 Disassembling Nokia 3395 Inner Components: stap 12, afbeelding 2 van 2
    • Vibrating unit.
    Vraag FixBot
    Voeg opmerking toe
  13. Disassembling Nokia 3395 Inner Components: stap 13, afbeelding 1 van 2 Disassembling Nokia 3395 Inner Components: stap 13, afbeelding 2 van 2
    Vraag FixBot
    Voeg opmerking toe
  14. Disassembling Nokia 3395 Inner Components: stap 14, afbeelding 1 van 2 Disassembling Nokia 3395 Inner Components: stap 14, afbeelding 2 van 2
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nico Lee
83 Reputatie
6 handleidingen geschreven
Cal Poly, Team 30-41, Garner Spring 2010 Lid van Cal Poly, Team 30-41, Garner Spring 2010
CPSU-GARNER-S10S30G41
4 Leden
23 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 43
Altijd: 3,368
