Ga door naar hoofdinhoud
Disassembling Nokia 2366i Motherboard
Wat je nodig hebt
  1. Disassembling Nokia 2366i Motherboard, Battery: stap 1, afbeelding 1 van 2 Disassembling Nokia 2366i Motherboard, Battery: stap 1, afbeelding 2 van 2
    • Turn off the phone.
    • Position the phone so that the back side is in view.
    Vraag FixBot
    Voeg opmerking toe
  2. Disassembling Nokia 2366i Motherboard: stap 2, afbeelding 1 van 1
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    • Remove the back battery cover.
    Vraag FixBot
    Voeg opmerking toe
  3. Disassembling Nokia 2366i Motherboard: stap 3, afbeelding 1 van 3 Disassembling Nokia 2366i Motherboard: stap 3, afbeelding 2 van 3 Disassembling Nokia 2366i Motherboard: stap 3, afbeelding 3 van 3
    • Insert the spudger between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • Carefully lift the battery out of the phone.
    • The battery lifts out of the phone easily.
    Vraag FixBot
    Voeg opmerking toe
  4. Disassembling Nokia 2366i Motherboard, Rear Case: stap 4, afbeelding 1 van 2 Disassembling Nokia 2366i Motherboard, Rear Case: stap 4, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver or your fingers to remove the rubber tabs at top back of the phone.
    Vraag FixBot
    Voeg opmerking toe
  5. Disassembling Nokia 2366i Motherboard: stap 5, afbeelding 1 van 2 Disassembling Nokia 2366i Motherboard: stap 5, afbeelding 2 van 2
    • Remove four 5mm screws from the back of the phone using a T6 Torx screwdriver:
    • 2 screws at the bottom
    • 2 screws at the top
    Vraag FixBot
    Voeg opmerking toe
  6. Disassembling Nokia 2366i Motherboard: stap 6, afbeelding 1 van 2 Disassembling Nokia 2366i Motherboard: stap 6, afbeelding 2 van 2
    • Rotate the phone clockwise so the edge is facing you.
    • Insert the spudger in tabs between the outer casing and the inside frame.
    • Slide the spudger upwards.
    • This will remove the rear case of the phone.
    Vraag FixBot
    Voeg opmerking toe
  7. Disassembling Nokia 2366i Motherboard: stap 7, afbeelding 1 van 1
    • The phone should now be in two different sections.
    • 1) The rear case of the phone.
    • 2) The motherboard and the rest of the phone.
    Vraag FixBot
    Voeg opmerking toe
  8. Disassembling Nokia 2366i Motherboard, Motherboard: stap 8, afbeelding 1 van 2 Disassembling Nokia 2366i Motherboard, Motherboard: stap 8, afbeelding 2 van 2
    • Use the spudger to lift off the yellow clip near the top right corner of the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  9. Disassembling Nokia 2366i Motherboard: stap 9, afbeelding 1 van 2 Disassembling Nokia 2366i Motherboard: stap 9, afbeelding 2 van 2
    • Rotate the phone counterclockwise so that the edge is facing you.
    • Use the spudger to lift the motherboard out of the base of the phone.
    • Remove the motherboard from the base of the phone.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jonathan Newman
516 Reputatie
4 handleidingen geschreven
Cal Poly, Team 1-14, Amido Winter 2011 Lid van Cal Poly, Team 1-14, Amido Winter 2011
CPSU-AMIDO-W11S1G14
5 Leden
20 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 44
Altijd: 1,916
